[Solved] Temperature Sensor - Pin Layout
Elco,
Just received my temp sensors. Can you let me know what wire is going to which pin. Plan on using with older arduino based brewpi.
Thanks
Covered here.
Red 5v
Black Gnd
White Data
Jack I was looking for which pin on the rj connector they are assigned to. I was able to find the info you posted but the wires are so darn small I cant know for sure which pins they are on.
Sorry, I misunderstood your original question
pin
1 = RS485-A
2 = 12V
3 = 5V
4 = GND
5 = OneWire
6 = RS485-B
So on the RJ11 connectors
2 = 5V
3 = GND
4 = One Wire
Pin 2 is blank. 3 4 and 5 are on the probe only
