Your mount for the auth service is missing the auth subdirectory, you are mounting the whole brewblox dir.
Thanks Elco, I updated the mapping path to /mnt/user/appdata/brewblox/auth and it created the users.passwords file but I am still getting the same 404 and error message.
Is there another file that should be created and but not being auto generated, if there is what is the file and I can try and get it added.
Thank you,
Are all services up? What is in the docker log for traefik?
Here is the only info in log for traefik.
time="2024-08-29T09:00:55-05:00" level=info msg="Configuration loaded from file: /config/traefik.yml"
time="2024-08-29T09:00:56-05:00" level=error msg="middleware \"auth@file\" does not exist" entryPointName=web routerName=web-to-websecure@internal
The Services that are currently running are:
- ui
- redis
- eventbus
- traefik
- sparkone
- victoria
- history
- auth
Do you have this file and the files it refers to?
location: brewblox/traefik/dynamic/brewblox-provider.yml
# DO NOT EDIT: THIS FILE WILL BE RESET DURING UPDATES
# This file contains dynamic configuration for the Traefik proxy.
# If you need to add or extend the dynamic configuration,
# You can add another .yml file in the same directory.
# For more information, see: https://doc.traefik.io/traefik/providers/file/
http:
routers:
api:
rule: PathPrefix(`/api`) || PathPrefix(`/dashboard`)
service: api@internal
middlewares:
prefix-strip:
stripPrefixRegex:
regex:
auth:
forwardAuth:
address: http://auth:5000/auth/verify
cors:
headers:
accessControlAllowCredentials: true
accessControlAllowOriginListRegex:
accessControlAllowMethods:
- CONNECT
- HEAD
- GET
- DELETE
- OPTIONS
- PATCH
- POST
- PUT
- TRACE
accessControlAllowHeaders:
- Origin
- X-Requested-With
- Content-Type
- Accept
tls:
stores:
default:
defaultCertificate:
certFile: /config/brew.blox/cert.pem
keyFile: /config/brew.blox/key.pem
serversTransport:
rootCAs:
- /config/minica.pem
Here is where we generate the certificates:
It is quite a hassle to not use brewblox-ctl!
I do not have those files. I’ll get those added.
I would prefer to use brewblox-ctl but I am using Unraid and I couldn’t get it to run. Unraid wants to run docker and terminal as root but I kept getting a message with breblox-ctl that it couldn’t be run as root.
If there is a better way to do this on Unraid, I’m all for it or if I need to be a tester I can do that as well.
These lines in your static config haven’t been resolved yet.
Assuming default config, these lines should be:
providers:
docker:
constraints: "LabelRegex(`com.docker.compose.project`, `brewblox`)"
defaultRule: 'PathPrefix(`/{{ index .Labels "com.docker.compose.service" }}`)'
