The docker ps entry for eventbus should include:
0.0.0.0:1883->1883/tcp
If it doesn’t, you may need to run docker-compose up -d to apply changes.
Hello Bob,all,
I managed to subscribe to the Eventbus state messages as written some messages below. I am lost however on extracting the specific PID output setting for my Induction cooker. I am still a Python noob.
Here’s what I’ve been trying so far:
import paho.mqtt.client as mqtt
import json
def on_connect(client, userdata, flags, rc):
print("Connected with result code "+str(rc))
# Subscribing in on_connect() means that if we lose the connection and
# reconnect then subscriptions will be renewed.
client.subscribe("brewcast/state/#")
def on_message(client, userdata, msg):
data = json.loads(msg.payload)
print(json.dumps(data, indent=6, separators=(". ", " = ")))
client = mqtt.Client()
client.on_connect = on_connect
client.on_message = on_message
client.connect(“192.168.188.45”, 1883, 60)
client.loop_forever()
The output
many nested nids
The particular one I am looking for is mid :115
“nid” = 115.
“groups” = [
0
“type” = “Pid”.
“data” = {
“outputValue” = 100.0.
“outputSetting” = 100.0.
“enabled” = true.
“active” = true.
“p” = 118.2939453125.
“i” = 0.19677734375.
“d” = -0.1416015625.
“derivativeFilter” = “FILT_45s”.
“integralReset” = 0.0.
“boilMinOutput” = 0.0.
“boilModeActive” = false.
“derivative[delta_degC / minute]” = 0.005028252628567342.
“drivenOutputId<ActuatorAnalogInterface,driven>” = “PWMMockInduktion”.
“inputSetting[degC]” = 28.0.
“integral[delta_degC * hour]” = 0.0.
“inputId” = “SetpointInduktion”.
“boilPointAdjust[delta_degC]” = 0.0.
“td[second]” = 30.
“inputValue[degC]” = 25.96142578125.
“kp[1 / degC]” = 58.0.
“outputId” = “PWMMockInduktion”.
“error[delta_degC]” = 2.03955078125.
“ti[second]” = 600
“id” = “PIDInduktion”
So I’d like to obtain the outputValue value only, store it in a variable and push that into a separate MQTT topic for the MQTT device to subscribe to.
I am failing miserably on parsing the JSON file for that particular value. Any hint is highly appreciated.
Many thanks and best regards,
Steffen
SERVICE_ID = 'spark-one' # replace with the name of your spark service
PID_ID = 'PIDInduktion' # replace with string ID of desired PID
BLOCK_EVT = 'Spark.blocks' # const value
if not msg.payload:
print('Discarding empty message')
return
state = json.loads(msg.payload)
state_key = state['key']
state_type = state['type']
if state_key != SERVICE_ID or state_type != BLOCK_EVT:
print(f'discarding state message: key={state_key} type={state_type}')
return
# Find first block in list with correct ID
# Returns default value arg (None) if not found
blocks = state['data'] # list
pid = next((block for block in blocks if block['id'] == PID_ID), None)
if pid is None:
print('PID not found in blocks')
return
outputValue = pid['data']['outputValue']
For reference:
block[‘id’] is guaranteed to be unique. id and nid (numeric ID) exist because the Spark has very little persistent memory. We use 16 bit numbers as ID there, and the Spark service links those with user-defined string IDs.
Edit: forum posts allow code blocks by using triple backticks:
code goes here
This prevents ‘#’ comments being rendered as header.
Hey Bob,
that worked !
Many Many thanks. I guess the rest is not difficult anymore.
I’ll report back soon.
Best regsrds,
Steffen
Best regards,
Steffen
