Thanks for confirming this was on 0.4.3. This bug is fixed in 0.4.4.
Your settings are saved and restored during the update process.
Basically, when I try to run a beer profile nothing happens and I get a socket error (32): broken pipe
Any help would be greatly appreciated.
Also, tried this on both Safari and Firefox and I am adding a picture of my set-up as I have read that this might matter.
It might be a too simple suggestion, but can you try restarting the pi with âsudo rebootâ?
Ok. Just tried sudo reboot and did not fix the problem. Also, bought a new microUSB adapter to connect rPi and BrewPi. Still getting the socket error, tho.
Can you try this:
sudo python /home/brewpi/brewpi.py --kill
sudo rm /home/brewpi/BEERSOCKET
The wait for the script to restart.
Dang. Still did not fix the problem. Here is a picture of the socket error read out and the contents of
sudo ls /home/brewpi/
The profile being â â made me think of another possible issue. Maybe your settings files got corrupted or something.
Can you run this:
cd /home/brewpi
git diff
git reset
rm ./settings/config.cfg
cd /var/www/html
git diff
git reset
rm ./config_user.php
If the output of git diff is not empty, let me know what it said.
If this doesnât help, please run the install script again for a clean install.
Ok. I did this but now I have a âcannot receive scriptâ problemâŚHere are the outputs for both git diff commands.
So, I canât tell if this fixed the problem because I have a âcannot receive scriptâ error. Any ideas?
can we talk on Skype? this seems to be inefficient. Iâd like to connect remotely and help you fix it. Iâll send you my skype name in PM.
