I do not know how to move an image from a HDMI monitor to here.
I was imagining taking a picture of it with a digital camera or smartphone camera.
Sorry could not fix the focus.
I hope this is better.
Hmm. Itās not clear what (if anything) would be the next item in the boot script. I wonder if it actually completed successfully but rasbian lite just doesnāt start local tty sessions on boot by default.
Can you post the output of the following command.
sudo tail /var/log/syslog
pi@raspberrypi:~ $ sudo tail /var/log/syslog
Jul 16 20:30:50 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 20:33:42 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 20:33:42 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 20:33:42 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 20:36:14 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 20:36:14 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 20:36:14 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 20:38:28 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 20:38:28 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 20:38:28 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
pi@raspberrypi:~ $
Okay, actually maybe just paste the whole log so I can see what happened during the boot. Iām not sure if those DHCPv6 issues are relevant.
sudo cat /var/log/syslog
olff, post:108, topic:235"]
[/quote]
pi@raspberrypi:~ $ sudo cat /var/log/syslog
Jul 10 01:21:20 raspberrypi fake-hwclock[97]: Wed 10 Jul 00:21:16 UTC 2019
Jul 10 01:21:20 raspberrypi kernel: [ 0.000000] Booting Linux on physical CPU 0x0
Jul 10 01:21:20 raspberrypi kernel: [ 0.000000] Linux version 4.19.57-v7+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1244 SMP Thu Jul 4 18:45:25 BST 2019
Jul 10 01:21:20 raspberrypi kernel: [ 0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
Jul 10 01:21:20 raspberrypi kernel: [ 0.000000] CPU: div instructions available: patching division code
Jul 10 01:21:20 raspberrypi systemd[1]: Mounted POSIX Message Queue File System.
Jul 10 01:21:20 raspberrypi kernel: [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Jul 10 01:21:20 raspberrypi systemd[1]: Started Load Kernel Modules.
Jul 10 01:21:20 raspberrypi kernel: [ 0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Rev 1.2
Jul 10 01:21:20 raspberrypi kernel: [ 0.000000] Memory policy: Data cache writealloc
Jul 10 01:21:20 raspberrypi kernel: [ 0.000000] cma: Reserved 8 MiB at 0x3ac00000
Jul 10 01:21:20 raspberrypi kernel: [ 0.000000] On node 0 totalpages: 242688
Jul 10 01:21:20 raspberrypi kernel: [ 0.000000] Normal zone: 2133 pages used for memmap
Jul 10 01:21:20 raspberrypi systemd[1]: Mounting Kernel Configuration File Systemā¦
Jul 10 01:21:20 raspberrypi kernel: [ 0.000000] Normal zone: 0 pages reserved
Jul 10 01:21:20 raspberrypi kernel: [ 0.000000] Normal zone: 242688 pages, LIFO batch:63
Jul 10 01:21:20 raspberrypi kernel: [ 0.000000] random: get_random_bytes called from start_kernel+0xac/0x4b4 with crng_init=0
Jul 10 01:21:20 raspberrypi systemd[1]: Condition check resulted in FUSE Control File System being skipped.
Jul 10 01:21:20 raspberrypi kernel: [ 0.000000] percpu: Embedded 17 pages/cpu s39488 r8192 d21952 u69632
Jul 10 01:21:20 raspberrypi kernel: [ 0.000000] pcpu-alloc: s39488 r8192 d21952 u69632 alloc=17*4096
Jul 10 01:21:20 raspberrypi kernel: [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
Jul 10 01:21:20 raspberrypi kernel: [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 240555
Jul 10 01:21:20 raspberrypi kernel: [ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 bcm2708_fb.fbwidth=1824 bcm2708_fb.fbheight=984 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=b499a0a9-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
Jul 10 01:21:20 raspberrypi kernel: [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Jul 10 01:21:20 raspberrypi systemd[1]: Starting Apply Kernel Variablesā¦
Jul 10 01:21:20 raspberrypi kernel: [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Jul 10 01:21:20 raspberrypi kernel: [ 0.000000] Memory: 939088K/970752K available (8192K kernel code, 629K rwdata, 2176K rodata, 1024K init, 821K bss, 23472K reserved, 8192K cma-reserved)
Jul 10 01:21:20 raspberrypi systemd[1]: Starting File System Check on Root Deviceā¦
Jul 10 01:21:20 raspberrypi kernel: [ 0.000000] Virtual kernel memory layout:
Jul 10 01:21:20 raspberrypi kernel: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
Jul 10 01:21:20 raspberrypi kernel: [ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
Jul 10 01:21:20 raspberrypi systemd[1]: Mounted Kernel Configuration File System.
Jul 10 01:21:20 raspberrypi kernel: [ 0.000000] vmalloc : 0xbb800000 - 0xff800000 (1088 MB)
Jul 10 01:21:20 raspberrypi kernel: [ 0.000000] lowmem : 0x80000000 - 0xbb400000 ( 948 MB)
Jul 10 01:21:20 raspberrypi kernel: [ 0.000000] modules : 0x7f000000 - 0x80000000 ( 16 MB)
Jul 10 01:21:20 raspberrypi kernel: [ 0.000000] .text : 0x(ptrval) - 0x(ptrval) (9184 kB)
Jul 10 01:21:20 raspberrypi systemd[1]: Started File System Check Daemon to report status.
Jul 10 01:21:20 raspberrypi systemd[1]: Started Apply Kernel Variables.
Jul 10 01:21:20 raspberrypi kernel: [ 0.000000] .init : 0x(ptrval) - 0x(ptrval) (1024 kB)
Jul 10 01:21:20 raspberrypi kernel: [ 0.000000] .data : 0x(ptrval) - 0x(ptrval) ( 630 kB)
Jul 10 01:21:20 raspberrypi kernel: [ 0.000000] .bss : 0x(ptrval) - 0x(ptrval) ( 822 kB)
Jul 10 01:21:20 raspberrypi kernel: [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
Jul 10 01:21:20 raspberrypi systemd[1]: Started udev Coldplug all Devices.
Jul 10 01:21:20 raspberrypi kernel: [ 0.000000] ftrace: allocating 26351 entries in 78 pages
Jul 10 01:21:20 raspberrypi kernel: [ 0.000000] rcu: Hierarchical RCU implementation.
Jul 10 01:21:20 raspberrypi kernel: [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
Jul 10 01:21:20 raspberrypi kernel: [ 0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
Jul 10 01:21:20 raspberrypi systemd-fsck[125]: e2fsck 1.44.5 (15-Dec-2018)
Jul 10 01:21:20 raspberrypi kernel: [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
Jul 10 01:21:20 raspberrypi systemd[1]: Starting Helper to synchronize boot up for ifupdownā¦
Jul 10 01:21:20 raspberrypi kernel: [ 0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
Jul 10 01:21:20 raspberrypi kernel: [ 0.000023] Switching to timer-based delay loop, resolution 52ns
Jul 10 01:21:20 raspberrypi kernel: [ 0.000284] Console: colour dummy device 80x30
Jul 10 01:21:20 raspberrypi systemd-fsck[125]: Superblock last write time is in the future.
Jul 10 01:21:20 raspberrypi kernel: [ 0.000901] console [tty1] enabled
Jul 10 01:21:20 raspberrypi kernel: [ 0.000957] Calibrating delay loop (skipped), value calculated using timer frequency⦠38.40 BogoMIPS (lpj=192000)
Jul 10 01:21:20 raspberrypi systemd-fsck[125]: #011(by less than a day, probably due to the hardware clock being incorrectly set)
Jul 10 01:21:20 raspberrypi kernel: [ 0.001003] pid_max: default: 32768 minimum: 301
Jul 10 01:21:20 raspberrypi kernel: [ 0.001358] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
Jul 10 01:21:20 raspberrypi kernel: [ 0.001394] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
Jul 10 01:21:20 raspberrypi kernel: [ 0.002323] CPU: Testing write buffer coherency: ok
Jul 10 01:21:20 raspberrypi systemd-fsck[125]: rootfs: clean, 42162/117360 files, 270342/468992 blocks
Jul 10 01:21:20 raspberrypi kernel: [ 0.002803] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Jul 10 01:21:20 raspberrypi kernel: [ 0.003480] Setting up static identity map for 0x100000 - 0x10003c
Jul 10 01:21:20 raspberrypi kernel: [ 0.003650] rcu: Hierarchical SRCU implementation.
Jul 10 01:21:20 raspberrypi kernel: [ 0.004473] smp: Bringing up secondary CPUs ā¦
Jul 10 01:21:20 raspberrypi systemd[1]: Started File System Check on Root Device.
Jul 10 01:21:20 raspberrypi kernel: [ 0.005330] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
Jul 10 01:21:20 raspberrypi kernel: [ 0.006264] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
Jul 10 01:21:20 raspberrypi systemd[1]: Started Helper to synchronize boot up for ifupdown.
Jul 10 01:21:20 raspberrypi kernel: [ 0.007128] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
Jul 10 01:21:20 raspberrypi kernel: [ 0.007248] smp: Brought up 1 node, 4 CPUs
Jul 10 01:21:20 raspberrypi systemd[1]: Starting Remount Root and Kernel File Systemsā¦
Jul 10 01:21:20 raspberrypi kernel: [ 0.007331] SMP: Total of 4 processors activated (153.60 BogoMIPS).
Jul 10 01:21:20 raspberrypi kernel: [ 0.007355] CPU: All CPU(s) started in HYP mode.
Jul 10 01:21:20 raspberrypi kernel: [ 0.007375] CPU: Virtualization extensions available.
Jul 10 01:21:20 raspberrypi kernel: [ 0.008362] devtmpfs: initialized
Jul 10 01:21:20 raspberrypi systemd[1]: Started Set the console keyboard layout.
Jul 10 01:21:20 raspberrypi kernel: [ 0.021286] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
Jul 10 01:21:20 raspberrypi kernel: [ 0.021566] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
Jul 10 01:21:20 raspberrypi systemd[1]: Started Remount Root and Kernel File Systems.
Jul 10 01:21:20 raspberrypi kernel: [ 0.021614] futex hash table entries: 1024 (order: 4, 65536 bytes)
Jul 10 01:21:20 raspberrypi kernel: [ 0.022220] pinctrl core: initialized pinctrl subsystem
Jul 10 01:21:20 raspberrypi kernel: [ 0.023104] NET: Registered protocol family 16
Jul 10 01:21:20 raspberrypi systemd[1]: Starting Flush Journal to Persistent Storageā¦
Jul 10 01:21:20 raspberrypi kernel: [ 0.026051] DMA: preallocated 1024 KiB pool for atomic coherent allocations
Jul 10 01:21:20 raspberrypi kernel: [ 0.031726] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
Jul 10 01:21:20 raspberrypi kernel: [ 0.031763] hw-breakpoint: maximum watchpoint size is 8 bytes.
Jul 10 01:21:20 raspberrypi kernel: [ 0.031981] Serial: AMBA PL011 UART driver
Jul 10 01:21:20 raspberrypi systemd[1]: Starting Create System Usersā¦
Jul 10 01:21:20 raspberrypi kernel: [ 0.034280] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
Jul 10 01:21:20 raspberrypi kernel: [ 0.069394] bcm2835-dma 3f007000.dma: DMA legacy API manager at (ptrval), dmachans=0x1
Jul 10 01:21:20 raspberrypi kernel: [ 0.071316] SCSI subsystem initialized
Jul 10 01:21:20 raspberrypi systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
Jul 10 01:21:20 raspberrypi kernel: [ 0.071551] usbcore: registered new interface driver usbfs
Jul 10 01:21:20 raspberrypi kernel: [ 0.071633] usbcore: registered new interface driver hub
Jul 10 01:21:20 raspberrypi kernel: [ 0.071746] usbcore: registered new device driver usb
Jul 10 01:21:20 raspberrypi systemd[1]: Starting Load/Save Random Seedā¦
Jul 10 01:21:20 raspberrypi kernel: [ 0.090305] raspberrypi-firmware soc:firmware: Attached to firmware from 2019-07-09 14:40, variant start
Jul 10 01:21:20 raspberrypi kernel: [ 0.100138] raspberrypi-firmware soc:firmware: Firmware hash is 6c3fe3f096a93de3b34252ad98cdccadeb534be2
Jul 10 01:21:20 raspberrypi kernel: [ 0.111816] clocksource: Switched to clocksource arch_sys_counter
Jul 10 01:21:20 raspberrypi kernel: [ 0.200610] VFS: Disk quotas dquot_6.6.0
Jul 10 01:21:20 raspberrypi systemd-sysusers[136]: Creating group systemd-coredump with gid 996.
Jul 10 01:21:20 raspberrypi kernel: [ 0.200724] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Jul 10 01:21:20 raspberrypi kernel: [ 0.200935] FS-Cache: Loaded
Jul 10 01:21:20 raspberrypi kernel: [ 0.201161] CacheFiles: Loaded
Jul 10 01:21:20 raspberrypi systemd-sysusers[136]: Creating user systemd-coredump (systemd Core Dumper) with uid 996 and gid 996.
Jul 10 01:21:20 raspberrypi kernel: [ 0.211269] NET: Registered protocol family 2
Jul 10 01:21:20 raspberrypi kernel: [ 0.212096] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
Jul 10 01:21:20 raspberrypi kernel: [ 0.212161] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
Jul 10 01:21:20 raspberrypi kernel: [ 0.212292] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
Jul 10 01:21:20 raspberrypi systemd[1]: Started Flush Journal to Persistent Storage.
Jul 10 01:21:20 raspberrypi kernel: [ 0.212497] TCP: Hash tables configured (established 8192 bind 8192)
Jul 10 01:21:20 raspberrypi kernel: [ 0.212651] UDP hash table entries: 512 (order: 2, 16384 bytes)
Jul 10 01:21:20 raspberrypi systemd[1]: Started Load/Save Random Seed.
Jul 10 01:21:20 raspberrypi kernel: [ 0.212718] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
Jul 10 01:21:20 raspberrypi kernel: [ 0.213049] NET: Registered protocol family 1
Jul 10 01:21:20 raspberrypi kernel: [ 0.213651] RPC: Registered named UNIX socket transport module.
Jul 10 01:21:20 raspberrypi systemd[1]: Started Create System Users.
Jul 10 01:21:20 raspberrypi kernel: [ 0.213679] RPC: Registered udp transport module.
Jul 10 01:21:20 raspberrypi kernel: [ 0.213701] RPC: Registered tcp transport module.
Jul 10 01:21:20 raspberrypi kernel: [ 0.213722] RPC: Registered tcp NFSv4.1 backchannel transport module.
Jul 10 01:21:20 raspberrypi kernel: [ 0.215356] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
Jul 10 01:21:20 raspberrypi systemd[1]: Starting Create Static Device Nodes in /devā¦
Jul 10 01:21:20 raspberrypi kernel: [ 0.218353] Initialise system trusted keyrings
Jul 10 01:21:20 raspberrypi kernel: [ 0.218570] workingset: timestamp_bits=14 max_order=18 bucket_order=4
Jul 10 01:21:20 raspberrypi kernel: [ 0.228394] FS-Cache: Netfs ānfsā registered for caching
Jul 10 01:21:20 raspberrypi systemd[1]: Started Create Static Device Nodes in /dev.
Jul 10 01:21:20 raspberrypi kernel: [ 0.228974] NFS: Registering the id_resolver key type
Jul 10 01:21:20 raspberrypi kernel: [ 0.229023] Key type id_resolver registered
Jul 10 01:21:20 raspberrypi kernel: [ 0.229045] Key type id_legacy registered
Jul 10 01:21:20 raspberrypi kernel: [ 0.229076] nfs4filelayout_init: NFSv4 File Layout Driver Registeringā¦
Jul 10 01:21:20 raspberrypi systemd[1]: Starting udev Kernel Device Managerā¦
Jul 10 01:21:20 raspberrypi kernel: [ 0.231382] Key type asymmetric registered
Jul 10 01:21:20 raspberrypi kernel: [ 0.231413] Asymmetric key parser āx509ā registered
Jul 10 01:21:20 raspberrypi kernel: [ 0.231485] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
Jul 10 01:21:20 raspberrypi systemd[1]: Reached target Local File Systems (Pre).
Jul 10 01:21:20 raspberrypi kernel: [ 0.231668] io scheduler noop registered
Jul 10 01:21:20 raspberrypi kernel: [ 0.231693] io scheduler deadline registered (default)
Jul 10 01:21:20 raspberrypi kernel: [ 0.231972] io scheduler cfq registered
Jul 10 01:21:20 raspberrypi kernel: [ 0.231998] io scheduler mq-deadline registered (default)
Jul 10 01:21:20 raspberrypi systemd[1]: Started udev Kernel Device Manager.
Jul 10 01:21:20 raspberrypi kernel: [ 0.232022] io scheduler kyber registered
Jul 10 01:21:20 raspberrypi kernel: [ 0.235211] bcm2708_fb soc:fb: FB found 1 display(s)
Jul 10 01:21:20 raspberrypi kernel: [ 0.285977] Console: switching to colour frame buffer device 228x61
Jul 10 01:21:20 raspberrypi systemd[1]: Found device /dev/serial1.
Jul 10 01:21:20 raspberrypi kernel: [ 0.314674] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 1824x984
Jul 10 01:21:20 raspberrypi kernel: [ 0.317095] bcm2835-rng 3f104000.rng: hwrng registered
Jul 10 01:21:20 raspberrypi mtp-probe: checking bus 1, device 3: ā/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1ā
Jul 10 01:21:20 raspberrypi mtp-probe: checking bus 1, device 4: ā/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5ā
Jul 10 01:21:20 raspberrypi mtp-probe: bus: 1, device: 4 was not an MTP device
Jul 10 01:21:20 raspberrypi mtp-probe: bus: 1, device: 3 was not an MTP device
Jul 10 01:21:20 raspberrypi systemd[1]: Found device /dev/disk/by-partuuid/b499a0a9-01.
Jul 10 01:21:20 raspberrypi systemd[1]: Starting File System Check on /dev/disk/by-partuuid/b499a0a9-01ā¦
Jul 10 01:21:20 raspberrypi systemd-udevd[147]: Using default interface naming scheme āv240ā.
Jul 10 01:21:20 raspberrypi systemd-fsck[234]: fsck.fat 4.1 (2017-01-24)
Jul 10 01:21:20 raspberrypi systemd-fsck[234]: /dev/mmcblk0p1: 217 files, 79941/516191 clusters
Jul 10 01:21:20 raspberrypi systemd-udevd[149]: Process ā/usr/sbin/alsactl -E HOME=/run/alsa restore 0ā failed with exit code 99.
Jul 10 01:21:20 raspberrypi systemd[1]: Started File System Check on /dev/disk/by-partuuid/b499a0a9-01.
Jul 10 01:21:20 raspberrypi systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
Jul 10 01:21:20 raspberrypi systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
Jul 10 01:21:20 raspberrypi systemd[1]: Mounting /bootā¦
Jul 10 01:21:20 raspberrypi systemd[1]: Condition check resulted in Huge Pages File System being skipped.
Jul 10 01:21:20 raspberrypi systemd[1]: Starting Load/Save RF Kill Switch Statusā¦
Jul 10 01:21:20 raspberrypi systemd[1]: Mounted /boot.
Jul 10 01:21:20 raspberrypi systemd[1]: Reached target Local File Systems.
Jul 10 01:21:20 raspberrypi systemd[1]: Starting Commit a transient machine-id on diskā¦
Jul 10 01:21:20 raspberrypi systemd[1]: Starting Create Volatile Files and Directoriesā¦
Jul 10 01:21:20 raspberrypi kernel: [ 0.317561] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
Jul 10 01:21:20 raspberrypi systemd[1]: Starting Set console font and keymapā¦
Jul 10 01:21:20 raspberrypi kernel: [ 0.318330] vc-sm: Videocore shared memory driver
Jul 10 01:21:20 raspberrypi kernel: [ 0.318790] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
Jul 10 01:21:20 raspberrypi kernel: [ 0.329954] brd: module loaded
Jul 10 01:21:20 raspberrypi kernel: [ 0.340590] loop: module loaded
Jul 10 01:21:20 raspberrypi systemd[1]: Starting Raise network interfacesā¦
Jul 10 01:21:20 raspberrypi kernel: [ 0.341300] Loading iSCSI transport class v2.0-870.
Jul 10 01:21:20 raspberrypi kernel: [ 0.342190] libphy: Fixed MDIO Bus: probed
Jul 10 01:21:20 raspberrypi kernel: [ 0.342411] usbcore: registered new interface driver lan78xx
Jul 10 01:21:20 raspberrypi systemd[1]: Starting Preprocess NFS configurationā¦
Jul 10 01:21:20 raspberrypi kernel: [ 0.342633] usbcore: registered new interface driver smsc95xx
Jul 10 01:21:20 raspberrypi kernel: [ 0.342815] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
Jul 10 01:21:20 raspberrypi kernel: [ 0.370851] dwc_otg 3f980000.usb: base=(ptrval)
Jul 10 01:21:20 raspberrypi kernel: [ 0.571245] Core Release: 2.80a
Jul 10 01:21:20 raspberrypi kernel: [ 0.571355] Setting default values for core params
Jul 10 01:21:20 raspberrypi systemd[1]: Started Load/Save RF Kill Switch Status.
Jul 10 01:21:20 raspberrypi kernel: [ 0.571529] Finished setting default values for core params
Jul 10 01:21:20 raspberrypi systemd[1]: Started Set console font and keymap.
Jul 10 01:21:20 raspberrypi kernel: [ 0.772018] Using Buffer DMA mode
Jul 10 01:21:20 raspberrypi kernel: [ 0.772127] Periodic Transfer Interrupt Enhancement - disabled
Jul 10 01:21:20 raspberrypi kernel: [ 0.772300] Multiprocessor Interrupt Enhancement - disabled
Jul 10 01:21:20 raspberrypi kernel: [ 0.772464] OTG VER PARAM: 0, OTG VER FLAG: 0
Jul 10 01:21:20 raspberrypi systemd[1]: nfs-config.service: Succeeded.
Jul 10 01:21:20 raspberrypi kernel: [ 0.772610] Dedicated Tx FIFOs mode
Jul 10 01:21:20 raspberrypi kernel: [ 0.773196] WARN::dwc_otg_hcd_init:1045: FIQ DMA bounce buffers: virt = bad04000 dma = 0xfad04000 len=9024
Jul 10 01:21:20 raspberrypi kernel: [ 0.773494] FIQ FSM acceleration enabled for :
Jul 10 01:21:20 raspberrypi kernel: [ 0.773494] Non-periodic Split Transactions
Jul 10 01:21:20 raspberrypi systemd[1]: Started Preprocess NFS configuration.
Jul 10 01:21:20 raspberrypi kernel: [ 0.773494] Periodic Split Transactions
Jul 10 01:21:20 raspberrypi kernel: [ 0.773494] High-Speed Isochronous Endpoints
Jul 10 01:21:20 raspberrypi kernel: [ 0.773494] Interrupt/Control Split Transaction hack enabled
Jul 10 01:21:20 raspberrypi systemd[1]: Condition check resulted in RPC security service for NFS client and server being skipped.
Jul 10 01:21:20 raspberrypi kernel: [ 0.787737] dwc_otg: Microframe scheduler enabled
Jul 10 01:21:20 raspberrypi kernel: [ 0.787798] WARN::hcd_init_fiq:457: FIQ on core 1
Jul 10 01:21:20 raspberrypi kernel: [ 0.794690] WARN::hcd_init_fiq:458: FIQ ASM at 80650d3c length 36
Jul 10 01:21:20 raspberrypi kernel: [ 0.801620] WARN::hcd_init_fiq:497: MPHI regs_base at bb810000
Jul 10 01:21:20 raspberrypi systemd[1]: Condition check resulted in RPC security service for NFS server being skipped.
Jul 10 01:21:20 raspberrypi kernel: [ 0.808452] dwc_otg 3f980000.usb: DWC OTG Controller
Jul 10 01:21:20 raspberrypi kernel: [ 0.815312] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
Jul 10 01:21:20 raspberrypi kernel: [ 0.822286] dwc_otg 3f980000.usb: irq 56, io mem 0x00000000
Jul 10 01:21:20 raspberrypi systemd[1]: Reached target NFS client services.
Jul 10 01:21:20 raspberrypi kernel: [ 0.829161] Init: Port Power? op_state=1
Jul 10 01:21:20 raspberrypi kernel: [ 0.836123] Init: Power Port (0)
Jul 10 01:21:20 raspberrypi kernel: [ 0.843231] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
Jul 10 01:21:20 raspberrypi systemd[1]: Reached target Remote File Systems (Pre).
Jul 10 01:21:20 raspberrypi kernel: [ 0.850293] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jul 10 01:21:20 raspberrypi kernel: [ 0.857308] usb usb1: Product: DWC OTG Controller
Jul 10 01:21:20 raspberrypi kernel: [ 0.864227] usb usb1: Manufacturer: Linux 4.19.57-v7+ dwc_otg_hcd
Jul 10 01:21:20 raspberrypi systemd[1]: Reached target Remote File Systems.
Jul 10 01:21:20 raspberrypi kernel: [ 0.871191] usb usb1: SerialNumber: 3f980000.usb
Jul 10 01:21:20 raspberrypi systemd[1]: Started Create Volatile Files and Directories.
Jul 10 01:21:20 raspberrypi systemd[1]: Starting Update UTMP about System Boot/Shutdownā¦
Jul 10 01:21:20 raspberrypi systemd[1]: Starting Network Time Synchronizationā¦
Jul 10 01:21:20 raspberrypi systemd[1]: Started Update UTMP about System Boot/Shutdown.
Jul 10 01:21:20 raspberrypi kernel: [ 0.878706] hub 1-0:1.0: USB hub found
Jul 10 01:21:20 raspberrypi kernel: [ 0.885637] hub 1-0:1.0: 1 port detected
Jul 10 01:21:20 raspberrypi systemd[1]: etc-machine\x2did.mount: Succeeded.
Jul 10 01:21:20 raspberrypi kernel: [ 0.893003] dwc_otg: FIQ enabled
Jul 10 01:21:20 raspberrypi kernel: [ 0.893010] dwc_otg: NAK holdoff enabled
Jul 10 01:21:20 raspberrypi kernel: [ 0.893015] dwc_otg: FIQ split-transaction FSM enabled
Jul 10 01:21:20 raspberrypi kernel: [ 0.893026] Module dwc_common_port init
Jul 10 01:21:20 raspberrypi systemd[1]: Started Commit a transient machine-id on disk.
Jul 10 01:21:20 raspberrypi kernel: [ 0.893332] usbcore: registered new interface driver usb-storage
Jul 10 01:21:20 raspberrypi kernel: [ 0.900490] mousedev: PS/2 mouse device common for all mice
Jul 10 01:21:20 raspberrypi kernel: [ 0.908281] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
Jul 10 01:21:20 raspberrypi systemd[1]: Started Raise network interfaces.
Jul 10 01:21:20 raspberrypi kernel: [ 0.915458] bcm2835-cpufreq: min=600000 max=1200000
Jul 10 01:21:20 raspberrypi kernel: [ 0.922878] sdhci: Secure Digital Host Controller Interface driver
Jul 10 01:21:20 raspberrypi kernel: [ 0.929758] sdhci: Copyright© Pierre Ossman
Jul 10 01:21:20 raspberrypi kernel: [ 0.937020] mmc-bcm2835 3f300000.mmcnr: could not get clk, deferring probe
Jul 10 01:21:20 raspberrypi kernel: [ 0.944340] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
Jul 10 01:21:20 raspberrypi systemd[1]: Started Network Time Synchronization.
Jul 10 01:21:20 raspberrypi kernel: [ 0.951500] sdhci-pltfm: SDHCI platform and OF driver helper
Jul 10 01:21:20 raspberrypi kernel: [ 0.960061] ledtrig-cpu: registered to indicate activity on CPUs
Jul 10 01:21:20 raspberrypi kernel: [ 0.967412] hidraw: raw HID events driver Ā© Jiri Kosina
Jul 10 01:21:20 raspberrypi kernel: [ 0.974751] usbcore: registered new interface driver usbhid
Jul 10 01:21:20 raspberrypi kernel: [ 0.981897] usbhid: USB HID core driver
Jul 10 01:21:20 raspberrypi kernel: [ 0.989844] vchiq: vchiq_init_state: slot_zero = (ptrval), is_master = 0
Jul 10 01:21:20 raspberrypi kernel: [ 0.998655] [vc_sm_connected_init]: start
Jul 10 01:21:20 raspberrypi kernel: [ 1.008921] [vc_sm_connected_init]: end - returning 0
Jul 10 01:21:20 raspberrypi kernel: [ 1.017087] Initializing XFRM netlink socket
Jul 10 01:21:20 raspberrypi kernel: [ 1.024035] NET: Registered protocol family 17
Jul 10 01:21:20 raspberrypi kernel: [ 1.030924] Key type dns_resolver registered
Jul 10 01:21:20 raspberrypi kernel: [ 1.038164] Registering SWP/SWPB emulation handler
Jul 10 01:21:20 raspberrypi kernel: [ 1.045609] registered taskstats version 1
Jul 10 01:21:20 raspberrypi kernel: [ 1.052425] Loading compiled-in X.509 certificates
Jul 10 01:21:20 raspberrypi kernel: [ 1.066512] uart-pl011 3f201000.serial: cts_event_workaround enabled
Jul 10 01:21:20 raspberrypi kernel: [ 1.073582] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 81, base_baud = 0) is a PL011 rev2
Jul 10 01:21:20 raspberrypi kernel: [ 1.082760] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
Jul 10 01:21:20 raspberrypi kernel: [ 1.089873] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
Jul 10 01:21:20 raspberrypi kernel: [ 1.111961] Indeed it is in host mode hprt0 = 00021501
Jul 10 01:21:20 raspberrypi systemd[1]: Reached target System Initialization.
Jul 10 01:21:20 raspberrypi kernel: [ 1.180015] sdhost: log_buf @ (ptrval) (fad07000)
Jul 10 01:21:20 raspberrypi kernel: [ 1.206566] random: fast init done
Jul 10 01:21:20 raspberrypi kernel: [ 1.227250] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
Jul 10 01:21:20 raspberrypi systemd[1]: Started Daily Cleanup of Temporary Directories.
Jul 10 01:21:20 raspberrypi kernel: [ 1.235912] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
Jul 10 01:21:20 raspberrypi kernel: [ 1.242872] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
Jul 10 01:21:20 raspberrypi kernel: [ 1.251192] of_cfs_init
Jul 10 01:21:20 raspberrypi kernel: [ 1.258206] of_cfs_init: OK
Jul 10 01:21:20 raspberrypi systemd[1]: Listening on D-Bus System Message Bus Socket.
Jul 10 01:21:20 raspberrypi kernel: [ 1.265824] Waiting for root device PARTUUID=b499a0a9-02ā¦
Jul 10 01:21:20 raspberrypi kernel: [ 1.271036] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
Jul 10 01:21:20 raspberrypi kernel: [ 1.282236] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
Jul 10 01:21:20 raspberrypi systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
Jul 10 01:21:20 raspberrypi kernel: [ 1.321590] mmc0: host does not support reading read-only switch, assuming write-enable
Jul 10 01:21:20 raspberrypi kernel: [ 1.331137] mmc0: new high speed SDHC card at address 0001
Jul 10 01:21:20 raspberrypi kernel: [ 1.338062] usb 1-1: new high-speed USB device number 2 using dwc_otg
Jul 10 01:21:20 raspberrypi kernel: [ 1.345281] Indeed it is in host mode hprt0 = 00001101
Jul 10 01:21:20 raspberrypi systemd[1]: Listening on triggerhappy.socket.
Jul 10 01:21:20 raspberrypi kernel: [ 1.413294] mmcblk0: mmc0:0001 EB1QT 29.8 GiB
Jul 10 01:21:20 raspberrypi kernel: [ 1.422590] mmcblk0: p1 p2
Jul 10 01:21:20 raspberrypi kernel: [ 1.464263] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
Jul 10 01:21:20 raspberrypi systemd[1]: Reached target Sockets.
Jul 10 01:21:20 raspberrypi kernel: [ 1.471520] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
Jul 10 01:21:20 raspberrypi kernel: [ 1.486099] mmc1: new high speed SDIO card at address 0001
Jul 10 01:21:20 raspberrypi kernel: [ 1.487841] devtmpfs: mounted
Jul 10 01:21:20 raspberrypi kernel: [ 1.505874] Freeing unused kernel memory: 1024K
Jul 10 01:21:20 raspberrypi systemd[1]: Reached target Basic System.
Jul 10 01:21:20 raspberrypi kernel: [ 1.513440] Run /sbin/init as init process
Jul 10 01:21:20 raspberrypi kernel: [ 1.592147] usb 1-1: New USB device found, idVendor=0424, idProduct=9514, bcdDevice= 2.00
Jul 10 01:21:20 raspberrypi kernel: [ 1.599412] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Jul 10 01:21:20 raspberrypi kernel: [ 1.607326] hub 1-1:1.0: USB hub found
Jul 10 01:21:20 raspberrypi systemd[1]: Starting rng-tools.serviceā¦
Jul 10 01:21:20 raspberrypi kernel: [ 1.614501] hub 1-1:1.0: 5 ports detected
Jul 10 01:21:20 raspberrypi kernel: [ 1.941877] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
Jul 10 01:21:20 raspberrypi systemd[1]: Starting Configure Bluetooth Modems connected by UARTā¦
Jul 10 01:21:20 raspberrypi kernel: [ 2.072153] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00, bcdDevice= 2.00
Jul 10 01:21:20 raspberrypi kernel: [ 2.079538] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Jul 10 01:21:20 raspberrypi kernel: [ 2.089679] smsc95xx v1.0.6
Jul 10 01:21:20 raspberrypi systemd[1]: Starting Regenerate SSH host keysā¦
Jul 10 01:21:20 raspberrypi kernel: [ 2.185440] smsc95xx 1-1.1:1.0 eth0: register āsmsc95xxā at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:eb:61:ad
Jul 10 01:21:20 raspberrypi kernel: [ 2.279830] NET: Registered protocol family 10
Jul 10 01:21:20 raspberrypi kernel: [ 2.289028] Segment Routing with IPv6
Jul 10 01:21:20 raspberrypi rngd[336]: rngd 2-unofficial-mt.14 starting upā¦
Jul 10 01:21:20 raspberrypi kernel: [ 2.291871] usb 1-1.5: new full-speed USB device number 4 using dwc_otg
Jul 10 01:21:20 raspberrypi kernel: [ 2.437569] random: systemd: uninitialized urandom read (16 bytes read)
Jul 10 01:21:20 raspberrypi kernel: [ 2.447872] usb 1-1.5: New USB device found, idVendor=2b04, idProduct=c008, bcdDevice= 2.50
Jul 10 01:21:20 raspberrypi kernel: [ 2.462252] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 10 01:21:20 raspberrypi rng-tools[331]: Starting Hardware RNG entropy gatherer daemon: rngd.
Jul 10 01:21:20 raspberrypi kernel: [ 2.462261] usb 1-1.5: Product: P1
Jul 10 01:21:20 raspberrypi kernel: [ 2.478993] usb 1-1.5: Manufacturer: Particle
Jul 10 01:21:20 raspberrypi kernel: [ 2.504295] usb 1-1.5: SerialNumber: 3e0051000851353532343835
Jul 10 01:21:20 raspberrypi systemd[1]: Started Manage Sound Card State (restore and store).
Jul 10 01:21:20 raspberrypi alsactl[343]: alsactl 1.1.8 daemon started
Jul 10 01:21:20 raspberrypi alsactl[343]: /usr/sbin/alsactl: load_state:1683Cannot open /var/lib/alsa/asound.state for reading: No such file or directory
Jul 10 01:21:20 raspberrypi systemd[1]: Starting Login Serviceā¦
Jul 10 01:21:20 raspberrypi alsactl[343]: Found hardware: ābcm2835_alsaā āBroadcom Mixerā āā āā āā
Jul 10 01:21:20 raspberrypi alsactl[343]: Hardware is initialized using a generic method
Jul 10 01:21:20 raspberrypi dd[335]: 1+0 records in
Jul 10 01:21:20 raspberrypi dd[335]: 1+0 records out
Jul 10 01:21:20 raspberrypi dd[335]: 4096 bytes (4.1 kB, 4.0 KiB) copied, 0.0425304 s, 96.3 kB/s
Jul 10 01:21:20 raspberrypi kernel: [ 3.326896] random: systemd: uninitialized urandom read (16 bytes read)
Jul 10 01:21:20 raspberrypi systemd[1]: Starting Save/Restore Sound Card Stateā¦
Jul 10 01:21:20 raspberrypi kernel: [ 3.385056] random: systemd: uninitialized urandom read (16 bytes read)
Jul 10 01:21:20 raspberrypi kernel: [ 3.448008] urandom_read: 3 callbacks suppressed
Jul 10 01:21:20 raspberrypi kernel: [ 3.448019] random: systemd: uninitialized urandom read (16 bytes read)
Jul 10 01:21:20 raspberrypi rngd[336]: entropy feed to the kernel ready
Jul 10 01:21:20 raspberrypi kernel: [ 3.482091] random: systemd: uninitialized urandom read (16 bytes read)
Had to chop it , 32000 max 85000 for whole file. Top of output.
Okay. Could you search for the āStarting Daily aptā line and then just post however much you can post starting from there.
Jul 16 17:22:02 raspberrypi systemd[1]: Started Daily apt download activities.
Jul 16 17:22:02 raspberrypi systemd[1]: Starting Daily apt upgrade and clean activitiesā¦
Jul 16 17:22:03 raspberrypi systemd[1]: apt-daily-upgrade.service: Succeeded.
Jul 16 17:22:03 raspberrypi systemd[1]: Started Daily apt upgrade and clean activities.
Jul 16 17:22:03 raspberrypi systemd[1]: Startup finished in 2.080s (kernel) + 1min 1.174s (userspace) = 1min 3.254s.
Jul 16 17:22:49 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 17:22:49 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 17:22:49 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 17:24:15 raspberrypi systemd[1]: Created slice User Slice of UID 1000.
Jul 16 17:24:15 raspberrypi systemd[1]: Starting User Runtime Directory /run/user/1000ā¦
Jul 16 17:24:15 raspberrypi systemd[1]: Started User Runtime Directory /run/user/1000.
Jul 16 17:24:15 raspberrypi systemd[1]: Starting User Manager for UID 1000ā¦
Jul 16 17:24:16 raspberrypi systemd[728]: Listening on GnuPG cryptographic agent and passphrase cache.
Jul 16 17:24:16 raspberrypi systemd[728]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
Jul 16 17:24:16 raspberrypi systemd[728]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
Jul 16 17:24:16 raspberrypi systemd[728]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
Jul 16 17:24:16 raspberrypi systemd[728]: Reached target Timers.
Jul 16 17:24:16 raspberrypi systemd[728]: Listening on GnuPG network certificate management daemon.
Jul 16 17:24:16 raspberrypi systemd[728]: Reached target Sockets.
Jul 16 17:24:16 raspberrypi systemd[728]: Reached target Paths.
Jul 16 17:24:16 raspberrypi systemd[728]: Reached target Basic System.
Jul 16 17:24:16 raspberrypi systemd[728]: Reached target Default.
Jul 16 17:24:16 raspberrypi systemd[728]: Startup finished in 272ms.
Jul 16 17:24:16 raspberrypi systemd[1]: Started User Manager for UID 1000.
Jul 16 17:24:16 raspberrypi systemd[1]: Started Session c1 of user pi.
Jul 16 17:24:54 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 17:24:54 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 17:24:54 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 17:27:02 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 17:27:02 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 17:27:02 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 17:28:09 raspberrypi systemd[1]: session-c1.scope: Succeeded.
Jul 16 17:28:19 raspberrypi systemd[1]: Stopping User Manager for UID 1000ā¦
Jul 16 17:28:19 raspberrypi systemd[728]: Stopped target Default.
Jul 16 17:28:19 raspberrypi systemd[728]: Stopped target Basic System.
Jul 16 17:28:19 raspberrypi systemd[728]: Stopped target Sockets.
Jul 16 17:28:19 raspberrypi systemd[728]: gpg-agent.socket: Succeeded.
Jul 16 17:28:19 raspberrypi systemd[728]: Closed GnuPG cryptographic agent and passphrase cache.
Jul 16 17:28:19 raspberrypi systemd[728]: gpg-agent-ssh.socket: Succeeded.
Jul 16 17:28:19 raspberrypi systemd[728]: Closed GnuPG cryptographic agent (ssh-agent emulation).
Jul 16 17:28:19 raspberrypi systemd[728]: Stopped target Timers.
Jul 16 17:28:19 raspberrypi systemd[728]: gpg-agent-browser.socket: Succeeded.
Jul 16 17:28:19 raspberrypi systemd[728]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
Jul 16 17:28:19 raspberrypi systemd[728]: Stopped target Paths.
Jul 16 17:28:19 raspberrypi systemd[728]: dirmngr.socket: Succeeded.
Jul 16 17:28:19 raspberrypi systemd[728]: Closed GnuPG network certificate management daemon.
Jul 16 17:28:19 raspberrypi systemd[728]: gpg-agent-extra.socket: Succeeded.
Jul 16 17:28:19 raspberrypi systemd[728]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
Jul 16 17:28:19 raspberrypi systemd[728]: Reached target Shutdown.
Jul 16 17:28:19 raspberrypi systemd[728]: systemd-exit.service: Succeeded.
Jul 16 17:28:19 raspberrypi systemd[728]: Started Exit the Session.
Jul 16 17:28:19 raspberrypi systemd[728]: Reached target Exit the Session.
Jul 16 17:28:19 raspberrypi systemd[1]: user@1000.service: Succeeded.
Jul 16 17:28:19 raspberrypi systemd[1]: Stopped User Manager for UID 1000.
Jul 16 17:28:19 raspberrypi systemd[1]: Stopping User Runtime Directory /run/user/1000ā¦
Jul 16 17:28:19 raspberrypi systemd[1]: run-user-1000.mount: Succeeded.
Jul 16 17:28:19 raspberrypi systemd[1]: user-runtime-dir@1000.service: Succeeded.
Jul 16 17:28:19 raspberrypi systemd[1]: Stopped User Runtime Directory /run/user/1000.
Jul 16 17:28:19 raspberrypi systemd[1]: Removed slice User Slice of UID 1000.
Jul 16 17:29:17 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 17:29:18 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 17:29:18 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 17:32:02 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 17:32:02 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 17:32:02 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 17:34:28 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 17:34:28 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 17:34:28 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 17:36:01 raspberrypi systemd[1]: Starting Cleanup of Temporary Directoriesā¦
Jul 16 17:36:01 raspberrypi systemd[1]: systemd-tmpfiles-clean.service: Succeeded.
Jul 16 17:36:01 raspberrypi systemd[1]: Started Cleanup of Temporary Directories.
Jul 16 17:37:16 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 17:37:16 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 17:37:16 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 17:39:27 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 17:39:27 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 17:39:27 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 17:42:22 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 17:42:22 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 17:42:22 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 17:45:02 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 17:45:02 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 17:45:02 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 17:47:13 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 17:47:13 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 17:47:13 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 17:49:23 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 17:49:23 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 17:49:23 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 17:51:50 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 17:51:50 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 17:51:50 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 17:54:25 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 17:54:25 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 17:54:25 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 17:56:56 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 17:56:56 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 17:56:56 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 17:59:14 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 17:59:14 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 17:59:14 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 18:01:23 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 18:01:23 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 18:01:23 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 18:04:15 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 18:04:15 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 18:04:15 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 18:07:12 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 18:07:12 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 18:07:12 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 18:09:31 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 18:09:32 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 18:09:32 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 18:09:49 raspberrypi systemd[1]: Created slice User Slice of UID 1000.
Jul 16 18:09:49 raspberrypi systemd[1]: Starting User Runtime Directory /run/user/1000ā¦
Jul 16 18:09:49 raspberrypi systemd[1]: Started User Runtime Directory /run/user/1000.
Jul 16 18:09:49 raspberrypi systemd[1]: Starting User Manager for UID 1000ā¦
Jul 16 18:09:49 raspberrypi systemd[947]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
Jul 16 18:09:49 raspberrypi systemd[947]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
Jul 16 18:09:49 raspberrypi systemd[947]: Listening on GnuPG network certificate management daemon.
Jul 16 18:09:49 raspberrypi systemd[947]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
Jul 16 18:09:49 raspberrypi systemd[947]: Reached target Paths.
Jul 16 18:09:49 raspberrypi systemd[947]: Reached target Timers.
Jul 16 18:09:49 raspberrypi systemd[947]: Listening on GnuPG cryptographic agent and passphrase cache.
Jul 16 18:09:49 raspberrypi systemd[947]: Reached target Sockets.
Jul 16 18:09:49 raspberrypi systemd[947]: Reached target Basic System.
Jul 16 18:09:49 raspberrypi systemd[947]: Reached target Default.
Jul 16 18:09:49 raspberrypi systemd[947]: Startup finished in 166ms.
Jul 16 18:09:49 raspberrypi systemd[1]: Started User Manager for UID 1000.
Jul 16 18:09:49 raspberrypi systemd[1]: Started Session c2 of user pi.
Jul 16 18:11:48 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 18:11:48 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 18:11:48 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 18:14:19 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 18:14:19 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 18:14:19 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 18:16:48 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 18:16:48 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 18:16:48 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 18:17:01 raspberrypi CRON[1017]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Jul 16 18:18:58 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 18:18:58 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 18:18:58 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 18:21:08 raspberrypi rngd[336]: stats: bits received from HRNG source: 80064
Jul 16 18:21:08 raspberrypi rngd[336]: stats: bits sent to kernel pool: 34848
Jul 16 18:21:08 raspberrypi rngd[336]: stats: entropy added to kernel pool: 34848
Jul 16 18:21:08 raspberrypi rngd[336]: stats: FIPS 140-2 successes: 4
Jul 16 18:21:08 raspberrypi rngd[336]: stats: FIPS 140-2 failures: 0
Jul 16 18:21:08 raspberrypi rngd[336]: stats: FIPS 140-2(2001-10-10) Monobit: 0
Jul 16 18:21:08 raspberrypi rngd[336]: stats: FIPS 140-2(2001-10-10) Poker: 0
Jul 16 18:21:08 raspberrypi rngd[336]: stats: FIPS 140-2(2001-10-10) Runs: 0
Jul 16 18:21:08 raspberrypi rngd[336]: stats: FIPS 140-2(2001-10-10) Long run: 0
Jul 16 18:21:08 raspberrypi rngd[336]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
Jul 16 18:21:08 raspberrypi rngd[336]: stats: HRNG source speed: (min=260.295; avg=409.997; max=889.644)Kibits/s
Jul 16 18:21:08 raspberrypi rngd[336]: stats: FIPS tests speed: (min=6.143; avg=6.623; max=7.064)Mibits/s
Jul 16 18:21:08 raspberrypi rngd[336]: stats: Lowest ready-buffers level: 2
Jul 16 18:21:08 raspberrypi rngd[336]: stats: Entropy starvations: 0
Jul 16 18:21:08 raspberrypi rngd[336]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
Jul 16 18:21:14 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 18:21:15 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 18:21:15 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 18:23:28 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 18:23:29 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 18:23:29 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 18:26:00 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 18:26:00 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 18:26:00 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 18:28:22 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 18:28:22 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 18:28:22 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 18:31:11 raspberrypi systemd-timesyncd[291]: Timed out waiting for reply from 159.203.82.102:123 (2.debian.pool.ntp.org).
Jul 16 18:31:19 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 18:31:19 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 18:31:19 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 18:31:21 raspberrypi systemd-timesyncd[291]: Timed out waiting for reply from 138.236.128.112:123 (2.debian.pool.ntp.org).
Jul 16 18:31:21 raspberrypi systemd-timesyncd[291]: Synchronized to time server for the first time 185.198.26.172:123 (2.debian.pool.ntp.org).
Jul 16 18:33:28 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 18:33:28 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 18:33:28 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 18:35:46 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 18:35:46 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 18:35:46 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 18:36:41 raspberrypi systemd[1]: Starting Daily apt download activitiesā¦
Jul 16 18:36:43 raspberrypi systemd[1]: apt-daily.service: Succeeded.
Jul 16 18:36:43 raspberrypi systemd[1]: Started Daily apt download activities.
Jul 16 18:38:12 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 18:38:12 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 18:38:12 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 18:41:10 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 18:41:10 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 18:41:10 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 18:43:13 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 18:43:13 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 18:43:13 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 18:45:20 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 18:45:20 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 18:45:20 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 18:47:50 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 18:47:50 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 18:47:50 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 18:49:54 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 18:49:54 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 18:49:54 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 18:52:36 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 18:52:36 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 18:52:36 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 18:54:58 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 18:54:58 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 18:54:58 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 18:57:49 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 18:57:49 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 18:57:49 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 19:00:03 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 19:00:03 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 19:00:03 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 19:02:52 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 19:02:52 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 19:02:52 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 19:05:24 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 19:05:24 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 19:05:24 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 19:07:30 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 19:07:30 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 19:07:30 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 19:09:57 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 19:09:57 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 19:09:57 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 19:12:41 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 19:12:41 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 19:12:41 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 19:15:19 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 19:15:19 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 19:15:19 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 19:17:01 raspberrypi CRON[1319]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Jul 16 19:18:18 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 19:18:18 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 19:18:18 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 19:20:30 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 19:20:30 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 19:20:30 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 19:21:08 raspberrypi rngd[336]: stats: bits received from HRNG source: 120064
Jul 16 19:21:08 raspberrypi rngd[336]: stats: bits sent to kernel pool: 64608
Jul 16 19:21:08 raspberrypi rngd[336]: stats: entropy added to kernel pool: 64608
Jul 16 19:21:08 raspberrypi rngd[336]: stats: FIPS 140-2 successes: 6
Jul 16 19:21:08 raspberrypi rngd[336]: stats: FIPS 140-2 failures: 0
Jul 16 19:21:08 raspberrypi rngd[336]: stats: FIPS 140-2(2001-10-10) Monobit: 0
Jul 16 19:21:08 raspberrypi rngd[336]: stats: FIPS 140-2(2001-10-10) Poker: 0
Jul 16 19:21:08 raspberrypi rngd[336]: stats: FIPS 140-2(2001-10-10) Runs: 0
Jul 16 19:21:08 raspberrypi rngd[336]: stats: FIPS 140-2(2001-10-10) Long run: 0
Jul 16 19:21:08 raspberrypi rngd[336]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
Jul 16 19:21:08 raspberrypi rngd[336]: stats: HRNG source speed: (min=260.295; avg=499.921; max=891.268)Kibits/s
Jul 16 19:21:08 raspberrypi rngd[336]: stats: FIPS tests speed: (min=6.143; avg=6.762; max=7.064)Mibits/s
Jul 16 19:21:08 raspberrypi rngd[336]: stats: Lowest ready-buffers level: 2
Jul 16 19:21:08 raspberrypi rngd[336]: stats: Entropy starvations: 0
Jul 16 19:21:08 raspberrypi rngd[336]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
Jul 16 19:23:01 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 19:23:01 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 19:23:01 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 19:25:34 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 19:25:34 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 19:25:34 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 19:28:32 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 19:28:32 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 19:28:32 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 19:31:00 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 19:31:00 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 19:31:00 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 19:33:16 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 19:33:16 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 19:33:16 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 19:35:35 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 19:35:35 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 19:35:35 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 19:37:44 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 19:37:44 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 19:37:44 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 19:40:06 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 19:40:07 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 19:40:07 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 19:42:46 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 19:42:46 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 19:42:46 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 19:45:05 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 19:45:05 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 19:45:05 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 19:47:48 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 19:47:48 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 19:47:48 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 19:49:50 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 19:49:50 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 19:49:50 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 19:52:43 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 19:52:43 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 19:52:43 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 19:54:48 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 19:54:48 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 19:54:48 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 19:57:00 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 19:57:00 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 19:57:00 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 19:59:18 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 19:59:18 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 19:59:18 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 20:02:00 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 20:02:00 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 20:02:00 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 20:04:08 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 20:04:08 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 20:04:08 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 20:06:56 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 20:06:56 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 20:06:56 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 20:09:31 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 20:09:31 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 20:09:32 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 20:12:06 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 20:12:06 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 20:12:06 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 20:14:19 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 20:14:19 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 20:14:19 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 20:16:53 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 20:16:53 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 20:16:53 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 20:17:01 raspberrypi CRON[1575]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Jul 16 20:19:27 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 20:19:27 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 20:19:27 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 20:21:08 raspberrypi rngd[336]: stats: bits received from HRNG source: 140064
Jul 16 20:21:08 raspberrypi rngd[336]: stats: bits sent to kernel pool: 94848
Jul 16 20:21:08 raspberrypi rngd[336]: stats: entropy added to kernel pool: 94848
Jul 16 20:21:08 raspberrypi rngd[336]: stats: FIPS 140-2 successes: 7
Jul 16 20:21:08 raspberrypi rngd[336]: stats: FIPS 140-2 failures: 0
Jul 16 20:21:08 raspberrypi rngd[336]: stats: FIPS 140-2(2001-10-10) Monobit: 0
Jul 16 20:21:08 raspberrypi rngd[336]: stats: FIPS 140-2(2001-10-10) Poker: 0
Jul 16 20:21:08 raspberrypi rngd[336]: stats: FIPS 140-2(2001-10-10) Runs: 0
Jul 16 20:21:08 raspberrypi rngd[336]: stats: FIPS 140-2(2001-10-10) Long run: 0
Jul 16 20:21:08 raspberrypi rngd[336]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
Jul 16 20:21:08 raspberrypi rngd[336]: stats: HRNG source speed: (min=260.295; avg=533.222; max=891.268)Kibits/s
Jul 16 20:21:08 raspberrypi rngd[336]: stats: FIPS tests speed: (min=6.143; avg=6.805; max=7.075)Mibits/s
Jul 16 20:21:08 raspberrypi rngd[336]: stats: Lowest ready-buffers level: 2
Jul 16 20:21:08 raspberrypi rngd[336]: stats: Entropy starvations: 0
Jul 16 20:21:08 raspberrypi rngd[336]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
Jul 16 20:21:32 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 20:21:32 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 20:21:32 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 20:23:39 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 20:23:39 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 20:23:39 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 20:25:42 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 20:25:42 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 20:25:42 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 20:28:32 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 20:28:32 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 20:28:32 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 20:30:50 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 20:30:50 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 20:30:50 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 20:33:42 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 20:33:42 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 20:33:42 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 20:36:14 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 20:36:14 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 20:36:14 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 20:38:28 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 20:38:28 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 20:38:28 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Jul 16 20:41:06 raspberrypi dhcpcd[537]: wlan0: Router Advertisement from fe80::c256:27ff:feb9:8ea3
Jul 16 20:41:06 raspberrypi dhcpcd[537]: wlan0: soliciting a DHCPv6 lease
Jul 16 20:41:06 raspberrypi dhcpcd[537]: wlan0: dropping DHCPv6 due to no valid routers
Okay, thanks. I could be wrong but Iām pretty sure there is actually no problem. It looks like startup finished correctly.
I would simply ignore the output from your monitor and use ssh to continue with the BrewBlox install guide starting from step 4.
Edit: I donāt know why rasbian didnāt launch a local tty session after boot completed (which is probably what was confusing you). Iām guessing that maybe it only does so if a keyboard is connected or something.
it is off and running! Thanks a whole lot!!!
I had problems so I disconnected the HDMI cable from the PI, and the USB cable to the Spark3, reformatted and loaded the Micro SD card and got the following message after step 5:
pi@raspberrypi:~ $ cd ./brewblox
-bash: cd: ./brewblox: No such file or directory
pi@raspberrypi:~ $
As part of step 4, did you run brewblox-ctl install, and what install directory did you choose?
I believe I typed in ./brewblox.
I am going to try to start fresh again to be sure. It ran quickly and looked clean on the install without the HDMI cable connected and the Spark 3 connected.
subprocess.CalledProcessError: Command ācurl -sL get.docker.com | sed ās/9)/9|10)/ā | shā returned non-zero exit status 100.
pi@raspberrypi:~ $ cd ~/brewblox
-bash: cd: /home/pi/brewblox: No such file or directory
pi@raspberrypi:~ $ pwd
/home/pi
pi@raspberrypi:~ $ cd /home/pi
pi@raspberrypi:~ $ cd /home/pi/brewblox
pi@raspberrypi:~ $
Third install attempt. At the brewblox directory prompt I entered ~/brewblox IAW instructions on step 4.3.
pi@raspberrypi:/home $ ls
pi
pi@raspberrypi:/home $ cd /pi
-bash: cd: /pi: No such file or directory
confusedā¦
This looks like docker failed to install. Docker have been playing catch up with the move to Debian Buster recently. Itās really annoyingā¦
The command thatās being run as a work around looks slightly wrong, though. Does the following work without throwing an error for you sudo curl -sL get.docker.com | sed 's/9)/10)/' | sh
