Yes sorry the script, and no the hard fault does not happen soon after, I have just left it after a AP switch and 15 mins later it still will not recover unless I power cycle the Spark.
Think we might have a couple of issues that seem to be related but might not be.
That’s only the system firmware from particle. I don’t think our user firmware is compatible, because its compiled against 0.5.3.
I think it would be a good test, but I think I’ll need to recompile the firmware for you. I expect breaking changes in the particle system firmware update, so I expect this to be non-trivial.
I’m deep in financial figures for the quarterly tax report, so I won’t have time for that this weekend.
Ok I won’t bother, It does seem to not be V3 specific during this testing I didn’t look at my V2 Spark which is also setup for wi-fi and that to has lost connection until I have rebooted it.
I assume it was moving between the AP;s during this testing swell.
I’ll temporarly config a seperate SSID that is only broadcast on one AP until you find a solution/fix.
If you need me to do any more testing let me know.
Terminating due to fatal serial error
Jul 29 2017 05:08:05 Notification: Script started for beer 'Cellar-01'
Jul 29 2017 05:08:05 Connecting to controller...
Jul 29 2017 05:08:05 Opening serial port
DEBUG:pySerial.socket:enabled logging
INFO:pySerial.socket:ignored port configuration change
INFO:pySerial.socket:ignored _update_dtr_state(True)
INFO:pySerial.socket:ignored _update_rts_state(True)
INFO:pySerial.socket:ignored reset_output_buffer
Jul 29 2017 05:08:05 Checking software version on controller...
Jul 29 2017 05:08:05 Found BrewPi v0.5.2 build 0.5.2-0-g72e633171, running on a Particle p1 with a V3 shield on port socket://192.168.0.240:6666?logging=debug
Jul 29 2017 05:31:04 Serial Error: read failed: [Errno 104] Connection reset by peer)
Exception in thread Thread-1:
File "/usr/lib/python2.7/threading.py", line 801, in __bootstrap_inner
self.run()
File "/usr/lib/python2.7/threading.py", line 754, in run
self.__target(*self.__args, **self.__kwargs)
File "/home/brewpi/backgroundserial.py", line 110, in __listen_thread
if self.writeln("") > 0:
File "/home/brewpi/backgroundserial.py", line 56, in writeln
return self.write(data + "\n")
File "/home/brewpi/backgroundserial.py", line 59, in write
self.exit_on_fatal_error()
File "/home/brewpi/backgroundserial.py", line 75, in exit_on_fatal_error
self.stop()
File "/home/brewpi/backgroundserial.py", line 38, in stop
self.thread.join() # wait for background thread to terminate
File "/usr/lib/python2.7/threading.py", line 931, in join
raise RuntimeError("cannot join current thread")
RuntimeError: cannot join current thread
Jul 29 2017 05:31:05 Lost serial connection. Cannot write to serial
Jul 29 2017 05:31:35 Notification: Script started for beer 'Cellar-01'
Jul 29 2017 05:31:35 Connecting to controller...
Jul 29 2017 05:31:35 Opening serial port
Jul 29 2017 05:31:36 Checking software version on controller...
Jul 29 2017 05:31:37 Found BrewPi v0.5.2 build 0.5.2-0-g72e633171, running on a Particle p1 with a V3 shield on port socket://192.168.0.240:6666?logging=debug
This thing just rebooted even while in off mode, what does that tell us?
As you can see from the first line “Temperature control disable” then an hour later two reboots in quick succession.
Jul 29 2017 06:27:00 Notification: Temperature control disabled
Jul 29 2017 06:27:00 Controller debug message: INFO MESSAGE 12: Received new setting: mode = o
Jul 29 2017 07:30:25 Error: controller is not responding anymore. Exiting script.
Jul 29 2017 07:30:55 Notification: Script started for beer 'None'
Jul 29 2017 07:30:55 Connecting to controller...
Jul 29 2017 07:30:55 Opening serial port
Jul 29 2017 07:30:55 Checking software version on controller...
Jul 29 2017 07:30:55 Found BrewPi v0.5.2 build 0.5.2-0-g72e633171, running on a Particle p1 with a V3 shield on port socket://192.168.0.240:6666?logging=debug
Jul 29 2017 07:31:14 Serial Error: socket disconnected)
Jul 29 2017 07:31:24 Lost serial connection. Error: Could not open port socket://192.168.0.240:6666?logging=debug: timed out)
Jul 29 2017 07:31:54 Notification: Script started for beer 'None'
Jul 29 2017 07:31:54 Connecting to controller...
Jul 29 2017 07:31:54 Opening serial port
Jul 29 2017 07:31:54 Checking software version on controller...
Jul 29 2017 07:31:55 Found BrewPi v0.5.2 build 0.5.2-0-g72e633171, running on a Particle p1 with a V3 shield on port socket://192.168.0.240:6666?logging=debug
That rules out a big part of the code. So it makes it more likely that it’s WiFi related. To rule out more, can you test with no devices connected and installed and in off mode?
You can do a factory reset by clicking the button at the bottom of advanced settings to go to that state.
Whole system reset yesterday at around 11:00, been in off mode all night with no issues then a reboot at 07:06
Jul 29 2017 09:30:14 Notification: Beer temperature set to 12.0 degrees in web interface
Jul 29 2017 09:30:14 Controller debug message: INFO MESSAGE 12: Received new setting: mode = b
Jul 29 2017 09:30:14 Controller debug message: INFO MESSAGE 12: Received new setting: beerSet = 12.0
Jul 29 2017 09:30:40 Notification: Restarted logging for beer 'Cellar-03'.
Jul 29 2017 11:13:42 Resetting controller to factory defaults
Jul 29 2017 11:13:43 Controller debug message: INFO MESSAGE 15: EEPROM initialized
Jul 29 2017 11:13:48 Resetting controller to factory defaults
Jul 29 2017 11:13:48 Controller debug message: INFO MESSAGE 15: EEPROM initialized
Jul 29 2017 11:13:54 Notification: Temperature control disabled
Jul 29 2017 11:13:55 Controller debug message: INFO MESSAGE 12: Received new setting: mode = o
Jul 30 2017 00:00:00 Notification: New day, creating new JSON file.
Jul 30 2017 07:06:15 Error: controller is not responding anymore. Exiting script.
Jul 30 2017 07:06:50 Notification: Script started for beer 'Cellar-03'
Jul 30 2017 07:06:50 Connecting to controller...
Jul 30 2017 07:06:50 Opening serial port
Jul 30 2017 07:06:50 Checking software version on controller...
Jul 30 2017 07:06:50 Found BrewPi v0.5.2 build 0.5.2-0-g72e633171, running on a Particle p1 with a V3 shield on port socket://192.168.0.240:6666?logging=debug
I assume this is pointing more towards a Wi-Fi related issue than before.
I have found a way to broadcast an SSID from only one AP using Zones. I will set up a new SSID and reset the P1 so that it knows only this SSID and keep you updated.
Mine appears to be doing the same thing. The WiFi signal in the room I have my equipment in is weak, but stable. Here are the logs for the past 30 minutes
Jul 30 2017 11:49:14 Fresh start! Log files erased.
Jul 30 2017 12:10:09 Error: controller is not responding anymore. Exiting script.
Jul 30 2017 12:10:41 Notification: Script started for beer 'Batch 51+52’
Jul 30 2017 12:10:41 Connecting to controller…
Jul 30 2017 12:10:41 Opening serial port
Jul 30 2017 12:10:41 Checking software version on controller…
Jul 30 2017 12:10:41 Found BrewPi v0.5.2 build 0.5.2-0-g72e633171, running on a Particle p1 with a V3 shield on port socket://192.168.86.35:6666
Jul 30 2017 12:13:36 Error: controller is not responding anymore. Exiting script.
Jul 30 2017 12:14:08 Notification: Script started for beer 'Batch 51+52’
Jul 30 2017 12:14:08 Connecting to controller…
Jul 30 2017 12:14:08 Opening serial port
Jul 30 2017 12:14:08 Checking software version on controller…
Jul 30 2017 12:14:08 Found BrewPi v0.5.2 build 0.5.2-0-g72e633171, running on a Particle p1 with a V3 shield on port socket://192.168.86.35:6666
@elco, looks like it is definitely when the P1 loses Wi-Fi or switches AP’s, since setting a new SSID an broadcasting on one AP only the V3 has not rebooted.
@bpascucci, I would suggest that this could more than likely be causing your issue to as I believe you have already worked out.
Later I’m going to add the devices again and put it back in Beer constant mode.
I’m not 100% sure it is the spark that is losing wifi, but possibly the pi. I’m monitoring pings to both devices and the pi is slower to respond and losing some packets here and there (1% or so). I’m wondering if the communication between the devices is the issue and there needs to be a higher socket timeout to addesss that. I may move my pi out of the room with the spark since they don’t have to be physically connected and see if that helps, but won’t make any changes till my fermentation is done. Don’t want to mess up my Oktoberfest.
I have compiled a new firmware version with the latest particle framework (0.7.0-rc.2).
Because of the system firmware update (0.5.3 -> 0.7.0) I need to make some changes to the update script to make sure you can update smoothly. I’ll try to do that as soon as possible. I am currently testing this version on my fridge.
There are some wifi related fixes in 0.7.0 that might resolve this. I have not been able to recreate the issue myself yet, so @rbpalmer if you want to be my guinea pig, that would be great. Just note that in case you want to downgrade the system firmware, a special order of commands is required.
@elco, really don’t mind being the guinea pig here, as you cannot recreate it and I can then it will make for a more stable platform across many different setups.
