If there is an easy solution to make virtual keyboard from chromium extension work, that would be great! Unfortunately I don’t have the knowledge to make it work
I can confirm that chrome extensions for virtual keyboards are useless.
The Pi virtual keyboard OnBoard did work.
To install:
sudo apt install -y onboard
To configure:
Pi start menu -> preferences -> onboard settings
General -> start onboard hidden, show floating icon when onboard is hidden
Window -> force window to top
Theme -> Nightshade (the default theme is -really- ugly)
Restart your Pi to apply the window setting.
When running, start onboard before launching kiosk mode.
I’ll make an issue for us to check out virtual keyboards on our end. You’re not the only one using kiosk mode, and we’d rather have things work out of the box. I can’t make any promises about how and when we’d implement it.
im about to give this a whirl. but if you do implement… I would think that even if it was just a numbers pad for temp and duty setting that you implemented would be sufficient. obviously I can’t speak for all but for me. any editing to system setup I would rather do from a computer. so full keyboard implementation would be awesome but not necessary… if
We’d strongly prefer some global solution that doesn’t need to be configured for each input field.
For the common use cases of eg. adjusting setpoints, next release already includes a widget that shows buttons / sliders for multiple predefined values and ranges.
yeah I suppose that makes sense. so I tried to use the onboard option but it doesn’t have any way to set up in raspbian lite from what I could read online. but In my hunt for trying to find a solution for scrollbar removal I was able to navigate to the extension store for chromium and I was able to install an onscreen keyboard from there. only problem is the same to OP had. inputs show but don’t actually take the setting. very oddddddd
Soooo with a little research it looks like these extension keyboards need the ability to write to local URL file. Which is an option under preferences of the extension settings of chromium.
Still does not work tho. Could be an issue with order of loading. Brewblox may be started prior to chromium. Or something along those line…
The brewblox UI is just a website: a bunch of html/js/css files downloaded and executed by your browser.
I suspect that the virtual keyboards try to inject chatacters in a place where the JS in the UI isn’t notified . I may give it another try some time, but I wasn’t much impressed with them to begin with: most of the ones I tried were blatantly stealing code / design, and I’d have to find the original first.
Haha. I’m not surprised!!! No worries. I’ll wait for a native one. It will be much better implemented and look better!!! Again thanks for the awesome support!!!
I tried matchbox. I didn’t like it. Took half of the screen. It’s not a pop up keyboard, no auto hide. Maybe you can do some codes to make it do those things, I just did a straight forward installation.
Can’t wait for Brewblox to implement virtual keyboard! That’s great!
Done that but my onscreen board shows questionmarks instead of characters. Pi setup localisation is set to english (UK), generic 101-key PC.
How can this be resolved?
Grts,
Erik
After this topic, we added on-screen keyboard support to Brewblox itself. It can be accessed from any input field in the UI.
Does that fix your use case, or was there some other reason you needed an on-screen keyboard?
Hi Bob, thank you for your fast reply.
The reason I would like a separate virtual keyboard is to use it with Raspberry Pi programs in general.
I cannot find support for the Onboard keyboard except on this forum, and I guess that is being superseded by the Brewblox application.
However if you might help, even indirectly with my issue with the Onboard keyboard I would be most thankful.
Kind regards,
Erik
