I did run it with sudo, below is the full output of the command. The script is able to connect to GitHub when updating the local /home/brewpi and /var/www branches, and when checking my local firmware version against the latest release, so it’s not clear why it fails on downloading firmware from GH:
pi@RaspberryBrewPi1 ~/brewpi-tools $ sudo python updater.py
#### Welcome to the BrewPi Updater! ####
Quit message sent to BrewPi instance with pid 5224!
You are on branch master
The latest commit in /home/brewpi is 4c7dfa342d8403eb2b485e9970e2cdec9e53c9e4 on Wed, 05 Aug 2015 14:15:44
The latest commit on origin/master is 4c7dfa342d8403eb2b485e9970e2cdec9e53c9e4 on Wed, 05 Aug 2015 14:15:44
The latest commit in /var/www is d44c03e786d0bde0dc43f86a8bd655659f3f3d2b on Wed, 11 Mar 2015 14:59:39
The latest commit on origin/master is d44c03e786d0bde0dc43f86a8bd655659f3f3d2b on Wed, 11 Mar 2015 14:59:39
Stopping any running instances of BrewPi to check/update controller...
Checking current firmware version...
Aug 23 2015 08:30:44 Opening serial port
Current firmware version on controller: 0.2.10
Checking GitHub for latest release...
Latest version on GitHub: 0.2.11
Version on GitHub is newer than your current version, downloading new version...
Downloading firmware failed
*** Done updating BrewPi! ***
I have the Brewpi Photon working and logging temps using the SSR expansion board, next Ia m going to hook up my SSR’s and then my fermentation chamber. One question I have is if the Touchscreen is supposed to control anything? So far I touch it and it doesn’t do anything. Are there any controls that I can change with the touchscreen? Thanks for any help.
Yep, i updated my core before upgrading the core to a Photon, I think Elco has changed the github fork for the new name for Spark.
If it doesn’t fix the issue then you could always copy down the original again. I have just tried setting mine back and get the same error. one I change Spark to Particle is works.
I updated my Spark Core to 0.2.11, and the update completed. On the first reboot after flashing the firmware I got the stuck on the stylus calibration screen, but on subsequent reboots I get the 4 flashes and then the standard BrewPi UI.
I had to query and re-install my devices and default settings, no big deal. But here’s the troubling thing: I no longer have cooling activity. When the freezer should kick on at the beginning of a cooling cycle it does nothing and I don’t hear the SSR click. But I do get the expected result for heating cycles! I recreated the device settings as they previously were (based on screenshots from a known working environment) so I am pretty sure they are correct.
My updater,py output is at bottom, and above that is what I see upon rebooting the Pi/BrewPi. Notice it says “running on a Particle Core” (which is not true)
Aug 24 2015 16:43:34 Opening serial port
Aug 24 2015 16:43:34 Notification: Script started for beer 'None'
Aug 24 2015 16:43:44 Checking software version on controller...
Aug 24 2015 16:43:45 Found BrewPi v0.2.11 build 0.2.11-0-ga28c22d, running on a Particle Core with a V1 shield on port /dev/ttyACM0
Quit message sent to BrewPi instance with pid 2507!
Aug 24 2015 16:10:53 Opening serial port
downloading https://github.com/BrewPi/firmware/releases/download/0.2.11/brewpi-0.2.11-core.bin
Latest firmware downloaded to /home/brewpi/utils/downloads/0.2.11/brewpi-0.2.11-core.bin
**** Spark Core Program script started ****
Aug 24 2015 16:10:56 Opening serial port
Checking current version: Found BrewPi v0.2.10 build 0.2.10-0-g2312560, running on a Particle Core with a V1 shield on port /dev/ttyACM0
Requesting old settings from Spark Core...
Saved old settings to file settings-Aug-24-2015-16-10-59.json
Waiting for the binary file to be sent ... (press 'a' to abort)
sent packet nr 0
sent packet nr 1
sent packet nr 2
sent packet nr 3
sent packet nr 4
sent packet nr 5
sent packet nr 6
sent packet nr 7
sent packet nr 8
sent packet nr 9
sent packet nr 10
sent packet nr 11
sent packet nr 12
sent packet nr 13
sent packet nr 14
sent packet nr 15
sent packet nr 16
sent packet nr 17
sent packet nr 18
sent packet nr 19
sent packet nr 20
sent packet nr 21
sent packet nr 22
sent packet nr 23
sent packet nr 24
sent packet nr 25
sent packet nr 26
sent packet nr 27
sent packet nr 28
sent packet nr 29
sent packet nr 30
sent packet nr 31
sent packet nr 32
sent packet nr 33
sent packet nr 34
sent packet nr 35
sent packet nr 36
sent packet nr 37
sent packet nr 38
sent packet nr 39
sent packet nr 40
sent packet nr 41
sent packet nr 42
sent packet nr 43
sent packet nr 44
sent packet nr 45
sent packet nr 46
sent packet nr 47
sent packet nr 48
sent packet nr 49
sent packet nr 50
sent packet nr 51
sent packet nr 52
sent packet nr 53
sent packet nr 54
sent packet nr 55
sent packet nr 56
sent packet nr 57
sent packet nr 58
sent packet nr 59
sent packet nr 60
sent packet nr 61
sent packet nr 62
sent packet nr 63
sent packet nr 64
sent packet nr 65
sent packet nr 66
sent packet nr 67
sent packet nr 68
sent packet nr 69
sent packet nr 70
sent packet nr 71
sent packet nr 72
sent packet nr 73
sent packet nr 74
sent packet nr 75
sent packet nr 76
sent packet nr 77
sent packet nr 78
sent packet nr 79
sent packet nr 80
sent packet nr 81
sent packet nr 82
sent packet nr 83
sent packet nr 84
sent packet nr 85
sent packet nr 86
sent packet nr 87
sent packet nr 88
sent packet nr 89
sent packet nr 90
sent packet nr 91
sent packet nr 92
sent packet nr 93
sent packet nr 94
sent packet nr 95
sent packet nr 96
sent packet nr 97
sent packet nr 98
sent packet nr 99
sent packet nr 100
sent packet nr 101
sent packet nr 102
sent packet nr 103
sent packet nr 104
sent packet nr 105
sent packet nr 106
sent packet nr 0
File flashed successfully
Waiting for device to reset.
Aug 24 2015 16:11:06 Opening serial port
Warning: Cannot receive version number from controller. Your controller is either not programmed yet or running a very old version of BrewPi. It will be reset to defaults.
INFO MESSAGE 15: EEPROM initialized
Now checking which settings and devices can be restored...
Warning: Cannot receive version number from controller after programming.
Something must have gone wrong. Restoring settings/devices settings failed.
BrewPi script will restart automatically.
Firmware update done
@rbpalmer Thank you so much for this tip! I was having the same problem as @DanCook and am also using a Spark Core, not Particle board, but making this change to the line you called out worked. I thought I was going crazy when it kept failing no matter what I did!
I suspect that applying the change recommended by @rbpalmer and then flashing my firmware to 0.2.11 has mangled the internal software / firmware logic governing Digital Output #3. That output, and its downstream SSR, used to turn my freezer on/off but this control path stopped working immediately upon flashing my firmware. By simply moving the green SSR terminal from Output #3 over to Output #1, then doing the relevant remapping in Device Configuration, the BrewPi can control the freezer once again.
Further data: I put the BrewPi Spark into Test mode and applied a volt meter on the 3 digital outputs. Output #3 is no longer sending 3V of DC control current when it is in ON mode, but the 2 other outputs continue to work as expected. This tells me the problem is not due to a physical defect in the control signal cables or their terminations, nor a fried SSR; the problem lies within the BrewPi Spark itself.
Is there a method for moving backward in a firmware versions? Or, assuming I need to have 3 working digital outputs at a later point, will I need to put the Core into DFU mode and flash that way?
Can you try running flashDfu to revert 0.2.11?
Run it with: python flashDfy.py --testmode to automatically apply test mode after updating.
The output voltage on the green terminals should be ~4.5V on USB, ~4.8V on 12V, not 3V.
Maybe your board is not getting enough power?
Or something is drawing too much power, try measuring the outputs with everything disconnected.
I was reading my analog multimeter wrong (didn’t have my glasses on). I am getting a tad over 4V at the digital output terminals #1 and #2 when I unplug the connectors. But I still don’t get any voltage on output #3.
I assume that in order to run flashDfu I need to put the Spark into DFU mode, and that the full text of the command is :
I went through the DFU update process, the output is shown below and I have working heating / cooling functions. Unfortunately I still have no voltage on output #3 and no SSR activity either. When I am in Test mode and I toggle all 3 outputs to ON, I can ‘peek under the hood’ and see what appear to be red LED bulbs on the Spark board for the two working outputs but no such glow corresponding to the faulty output. Then again I’m not sure if a red glow was visible on output #3 when it was previously working.
pi@RaspberryBrewPi1 ~ $ sudo python /home/brewpi/utils/flashDfu.py --testmode
Will set device to test mode after flashing
Detecting DFU devices
Found 1 devices: ['1d50:607f']
Device identified as Spark Core
Latest stable version on GitHub: 0.2.11
Firmware downloaded to /home/brewpi/utils/downloads/0.2.11/brewpi-0.2.11-core.bin
Now writing BrewPi firmware /home/brewpi/utils/downloads/0.2.11/brewpi-0.2.11-core.bin
dfu-util 0.7
Filter on vendor = 0x1d50 product = 0x607f
Opening DFU capable USB device... ID 1d50:607f
Found DFU: [1d50:607f] devnum=0, cfg=1, intf=0, alt=0, name="@Internal Flash /0x08000000/20*001Ka,108*001Kg"
Claiming USB DFU Interface...
Determining device status: state = dfuERROR, status = 10
dfuERROR, clearing status
dfuIDLE, continuing
Device returned transfer size 1024
No valid DFU suffix signature
Downloading to address = 0x08005000, size = 108140
File downloaded successfully
Transitioning to dfuMANIFEST state
Opening serial port
Aug 31 2015 09:23:51 Opening serial port
Success! Found BrewPi v0.2.11 build 0.2.11-0-ga28c22d, running on a Particle Core with a V1 shield on port /dev/ttyACM1
INFO MESSAGE 12: Received new setting: mode = t
I have confirmed the issue. This is a software problem in the firmware.
I have not figured it out yet. I can step debug and I see the digitalWrite happening on the correct pin (a0/10), but it does not change value when I check it with a multimeter.
Which is the correct pin nr according to the Spark Core pin layout:
All other pins work when toggling the inversion in device manager. It also works fine on the Photon. The hardware abstraction layer in the Particle framework should make both device behave the same. @mdma, do you have a clue what is going on?
Could it be related to that pin being the wake up pin? Did something change in the default configuration of the pin?
@Elco i haven’t updated my brewpi core since I first set it up in ~April, should I run the update script? I haven’t been around here for a while and haven’t been keeping up with the chit chat, so just wanted to make sure I don’t mess anything up! Cheers
What do I do to update to 0.4.5? Sorry I’m not terribly tech inclined!
I should also ask if this is something I need to do? Does it effect basic functioning of the brewpi for fermentation purposes (just a fridge and a heater)?
Actually, what I just noticed is that I am still on 0.2.8 on my core. @Elco should I run updater?
