What happens if you use 10% or 15%?
The pump turns off under 15%. I think maybe a software change is needed to ensure the pump always gets a pwm pulse.
A workaround is to set a minimum value on the pwm actuator.
So it’s happened from any % first time it ever happened I had it set to 14% went to zero and pump ran at 100%
So do I run the logs while it’s set to zero and pump spinning at 100%???
Yes, thanks!
@Elco this looks worth investigating: desired / achieved on PWM = 0, and desired state on pin is still active.
Thanks, bug confirmed and fixed.
It was a simple software bug:
We will release this soon.
