Yes the DS2408 boards
I see also there is also an option for 2 port or 10 port boards - I have never seen them for sale, are they going to be available to buy?
There’s some demand, so we may bring them back, but we designed the GPIO module to be a replacement that doesn’t suffer from their drawbacks.
If a onewire extension board loses connection, it can be left stuck open.
We’re considering how to either deal with this problem, or to make users sufficiently aware that they can install their own safeguards.
I like the idea of moving away from onewire, but do not know how I would wire up the new gpio module to drive the 5 wire ball valves. Can it be done?
Yes, the GPIO module can control valves. Do be aware that there’s an issue right now where inrush current causes the module to error out due to overcurrent. There’s a workaround with a resistor, and next patch will include a software fix.
Thanks Bob, do you have a diagram on how to wire these valves into the gpio module. I assume you would just wire the +ve to 8 pins - 2 modules - but not sure how the other 4 wire are configured.
Many thanks
Electric Ball Valve - Losing Power on GPIO Pin should be a useful reference, including discussion on how to work around overcurrent problems.
Good afternoon
Not sure if I am in the right place, but I guess two questions - I am trying to rebuild a system, that I think I broke by shorting something - Got a new GPIO and am confused how to assign the input voltage - i.e. power on the last pins.
I See this
But previous posts have this
So is there anything that explains how to attach 12v connection, or is this Something to do with SPI Error?
Brand new GPIO, so trying to figure out if I have not understood how to configure it, or whether it needs to be done differently, or if I have pooched the spark. Any ideas, getting bored with drinking Heineken.
Thanks in advance
I can’t conclusively say at a distance whether you already fried the module. You provide input voltage to the Spark by attaching the leads to the separate right-most terminals, as indicated by the orange block. After doing so, you switch that toggle in the second screen from “5V” to “External” to use the external power supply you just connected.
SPI error suggests that there is no communication at all with the module. If this is a new module, it is likely that the spark 4 is also damaged.
OK, thanks - I will order another Spark.
Regards
Warren
