I have 2 brewpi Spark 2 units. Both are configured exactly the same, both controlling identical 7 gallon SS Brewtech fermenters. The heat on one is consistently failing to meet target. On my last brew, it was missing by about a degree. At first I thought it might be the heating pad but its able to maintain higher temps, it just never actually meets target. The one thing I noticed is that the Duty Cycle on Heater 1 is 0 on the “good” one and 36.something on the bad, but there’s no setting for this. Any suggestions on troubleshooting?
Here’s a beer I’m brewing right now. Very tightly controlled. Not sure what caused that drop, but it might have been because I reused an old profile and moved some dates around. Also, yes, I did some manual edits to the html to put labels on the log probes. And yes, my basement gets that cold.
And this is just 5 gallons of Starsan I’m playing with. As you can see its obviously able to hit higher temps than it was maintaining before the ramp.
This is the good control algorithm
"kind": "Control",
"pids": [
"kind": "Pid",
"name": "heater1pid",
"enabled": true,
"input": {
"kind": "SensorSetPointPair",
"sensor": {
"kind": "TempSensorFallback",
"onBackupSensor": true,
"sensor": {
"kind": "TempSensorDelegate",
"name": "beer1",
"delegate": {
"kind": "OneWireTempSensor",
"value": 16.75,
"connected": true,
"address": "28D1FB030900003D",
"settings.calibrationOffset": 0
"setPoint": {
"kind": "SetPointSimple",
"name": "fridgeset",
"value": 16.668
"output": {
"kind": "ActuatorPwm",
"dutySetting": 0,
"period": 4,
"minVal": 0,
"maxVal": 100,
"target": {
"mutexGroup": {
"kind": "ActuatorMutexGroup",
"deadTime": 1800000,
"waitTime": 1016134
"target": {
"kind": "ActuatorDigitalDelegate",
"name": "heater1",
"delegate": {
"state": 0,
"kind": "ActuatorPin",
"pin": 25,
"invert": false
"inputError": 0.0508,
"Kp": 60,
"Ti": 3600,
"Td": 120,
"p": -3.0469,
"i": 0,
"d": -0.2344,
"actuatorIsNegative": false
"kind": "Pid",
"name": "heater2pid",
"enabled": true,
"input": {
"sensor": {
"name": "beer2",
"delegate": {
"value": null,
"connected": false
"setPoint": {
"name": "beer2set",
"value": null
"output": {
"dutySetting": 0,
"period": 4,
"minVal": 0,
"maxVal": 100,
"target": {
"mutexGroup": {
"waitTime": 1016131
"target": {
"name": "heater2",
"delegate": {
"kind": "ActuatorNop",
"state": 0
"inputError": null,
"Kp": 10,
"Ti": 600,
"Td": 60,
"p": 0,
"i": 0,
"d": 0,
"kind": "Pid",
"name": "coolerpid",
"enabled": true,
"input": {
"sensor": {
"sensor": {
"name": "beer1",
"delegate": {
"value": 16.75,
"connected": true,
"setPoint": {
"value": 16.668
"output": {
"dutySetting": 1.1641,
"period": 120,
"minVal": 0,
"maxVal": 100,
"target": {
"mutexGroup": {
"waitTime": 1016127
"target": {
"minOnTime": 10,
"minOffTime": 0,
"maxOnTime": 65535,
"state": 0,
"target": {
"name": "cooler",
"delegate": {
"state": 0,
"pin": 24,
"invert": false
"Kp": 10,
"Ti": 3600,
"Td": 120,
"p": -0.5078,
"i": -0.6172,
"d": -0.0391,
"actuatorIsNegative": true
"kind": "Pid",
"name": "beer2fridgepid",
"enabled": true,
"input": {
"sensor": {
"name": "beer1",
"delegate": {
"value": 16.75,
"connected": true,
"setPoint": {
"name": "beer1set",
"value": 16.668
"output": {
"kind": "ActuatorOffset",
"target": {
"sensor": {
"sensor": {
"name": "beer1",
"delegate": {
"value": 16.75,
"connected": true,
"setPoint": {
"value": 16.668
"reference": {
"sensor": {
"name": "beer1",
"delegate": {
"value": 16.75,
"connected": true,
"setPoint": {
"name": "beer1set",
"value": 16.668
"useReferenceValue": false,
"setting": 0,
"achieved": 0.082,
"minimum": 0,
"maximum": 0
"Kp": 0,
"Ti": 0,
"Td": 0,
"p": 0,
"i": 0,
"d": 0,
and the “bad”
"kind": "Control",
"pids": [
"kind": "Pid",
"enabled": true,
"input": {
"sensor": {
"sensor": {
"name": "beer1",
"delegate": {
"value": 17.75,
"connected": true,
"address": "283836030900004C",
"calibrationOffset": 0
"setPoint": {
"value": 18.332
"output": {
"dutySetting": 36.1094,
"period": 4,
"minVal": 0,
"maxVal": 100,
"target": {
"mutexGroup": {
"waitTime": 1754748
"target": {
"name": "heater1",
"delegate": {
"state": false,
"pin": 25,
"invert": false
"inputError": -0.5664,
"Kp": 60,
"Ti": 3600,
"Td": 120,
"p": 33.9844,
"i": 4,
"d": -1.875,
"kind": "Pid",
"enabled": true,
"input": {
"sensor": {
"name": "beer2",
"delegate": {
"value": null,
"connected": false
"setPoint": {
"name": "beer2set",
"value": null
"output": {
"dutySetting": 0,
"period": 4,
"minVal": 0,
"maxVal": 100,
"target": {
"mutexGroup": {
"waitTime": 1754745
"target": {
"name": "heater2",
"delegate": {
"state": false
"inputError": null,
"Kp": 10,
"Ti": 600,
"Td": 0,
"p": 0,
"i": 0,
"d": 0,
"kind": "Pid",
"enabled": true,
"input": {
"sensor": {
"sensor": {
"name": "beer1",
"delegate": {
"value": 17.75,
"connected": true,
"setPoint": {
"value": 18.332
"output": {
"dutySetting": 0,
"period": 120,
"minVal": 0,
"maxVal": 100,
"target": {
"mutexGroup": {
"waitTime": 1754742
"target": {
"minOnTime": 10,
"minOffTime": 0,
"maxOnTime": 65535,
"state": false,
"target": {
"name": "cooler",
"delegate": {
"state": false,
"pin": 24,
"invert": false
"Kp": 10,
"Ti": 3600,
"Td": 120,
"p": 5.6641,
"i": 0,
"d": -0.3125,
"kind": "Pid",
"enabled": true,
"input": {
"sensor": {
"name": "beer1",
"delegate": {
"value": 17.75,
"connected": true,
"setPoint": {
"name": "beer1set",
"value": 18.332
"output": {
"target": {
"sensor": {
"sensor": {
"name": "beer1",
"delegate": {
"value": 17.75,
"connected": true,
"setPoint": {
"value": 18.332
"reference": {
"sensor": {
"name": "beer1",
"delegate": {
"value": 17.75,
"connected": true,
"setPoint": {
"name": "beer1set",
"value": 18.332
"setting": 0,
"achieved": -0.582,
"minimum": 0,
"maximum": 0
"Kp": 0,
"Ti": 0,
"Td": 0,
"p": 0,
"i": 0,
"d": 0,
