The top 1 and top 2 actuators have a different hardware implementation so they can also be used as inputs. When they are configured as outputs by assigning a digital actuator block to them, they are configured as output and will toggle between 0 and 5V. When powered from USB it will be 4,5V.
I tested the latest version here and Top 1 and Top 2 work fine on my Spark 3.
What do you have connected to the output and how did you connect it? Did you run both the - and + from the green terminal? Between which pins are you measuring the voltage?
I am trying to control two DC SSR’s with the two outputs. If I connect the wires that are connected to the SSR to another output it works just fine. Looks not like a wiring issue to me.
I created a digital actuator pin and assigned it in the SparkPins ‘widget’ to an output. If I reassign an actuator that didnt work on top1 and top2 to another output it works fine.
Just now I measured again, this time directly on the pins in the connector on top off the spark. I made sure I didn’t short the pins . I measured the same values.
Top1 is around 2.5 Volts without anything assigned. With an assigined actuator switched on it goes to 2.6 Volts
Top2 is 0 volts in all cases
My question about the wiring was also because I have damaged a Spark 3 myself by sharing a ground wire for multiple actuators. Using ground from another point than the same green connector could cause a temporary voltage difference that can damage the output driver in freak events.
I never connected the wiring with a shared ground.
Actually I never used these outputs before. In the past I only used bottem 1&2 for two SSRs for my heaters. Now I added two SSRs for the pumps.
