LBussy
August 7, 2016, 11:15am
#1
I did some searching but did not find anyone talking about this. Has anyone added a door switch to a fridge that had none? Any ideas for a switch to use?
I was thinking one of these might be good:
This is the Magnetic Door Switch Set, a small reed switch assembly specifically designed to alert you when doors, drawers, or any other aperture opens. The
It’s rated for up to 500 mA, I think the Arduino can only do 40 mA on the I/O pins?
Any magnetic “reed switch” like the one LBussy suggests should work as it only needs to complete the circuit.
Or you can simply use tape, aluminum foil and exposed wires .
LBussy
August 11, 2016, 9:07pm
#3
I hope you will take my reply in the manner in which it was intended when I say that is the least high tech solution ever.
Hell, I’m sure it works great though.
