I recently upgraded to 2011/1/11 release. How do I add a service for Tilt? I found the widget, but only see the Spark service with no option to add a new service.
As soon as your Tilt service publishes data, it will be auto-detected and show up in the sidebar.
As I understand, an update for the Tilt service was released an hour or two before you posted. You may want to run brewblox-ctl service pull tilt.
I tried brewblox-ctl service pull tilt and received the following:
pi@raspberrypi:~/brewblox $ brewblox-ctl service pull tilt
ERROR: No such service: tilt
Command ‘docker-compose pull tilt’ returned non-zero exit status 1.
Ok think I have it working by doing this:
You need to add the service and set the eventbus port in your docker-compose.yml file.
tilt:
image: j616s/brewblox-tilt:latest
restart: unless-stopped
privileged: true
network_mode: host
volumes:
- ./tilt:/share
Finally, you’ll have to bring up the new service using
brewblox-ctl up
I tried earlier, but must have made a copy/paste error.
Hi!
Is this done by using the editor? Or do you have to use pull?
Thanks,
Bart
Pull will only update services already added.
The tilt service has an install script. For instructions: https://github.com/j616/brewblox-tilt#install-script
