Automated installation not working
I run the automated script but only the installation log appears in the two folder /home/brewpi and /var/www. What might be the problem?
Resolved!
You have to reply with “y” when asked where to install the brew software. if you hit enter the script exits.
Isn’t it the other way around? If you answer ‘y’, it tries to install into the directory ‘y’, which is not a valid path.
If you accept the defaults with enter, it uses the default install path.
I tried hitting just enter several times but when it asked if i wanted to use /var/www i had to type ‘y’. Otherwise it would quit.
