I backed up Brewblox using backup save command. It save a .tar.gz file, which is not acceptable as input, so extracted it on my Mac, zipped it loaded onto my freshly installed Raspberry Pi. Then ran Brewblox backup load and update but no signs of dashboards or other configurations in the web-ui. Apart from that it seems to be working fine.
pi@raspberrypi:~/brewblox $ brewblox-ctl backup load brewblox.zip
INFO       docker-compose.yml file not found in backup archive
INFO       No datastore files found in backup archive
INFO       No Spark files found in backup archive
INFO       Updating brewblox…
Do you want to remove old docker images to free disk space? [Y/n]: y
INFO       Updating brewblox-ctl…
INFO       Updating brewblox-ctl libs…
Digest: sha256:364b3a220c02b393a4ceef616ea90f5b97bf92de65fa7db7825222ec15e7b81b
Status: Image is up to date for brewblox/brewblox-ctl-lib:edge
752aa64376c143aed0f627856538213fc26592af2496291a68c7ff448a10fc93
ctl-lib
INFO       Checking Avahi config…
INFO       Stopping services…
INFO       Migrating configuration files…
INFO       Checking .env variables…
INFO       Pulling docker images…
Pulling history   … done
Pulling ui        … done
Pulling eventbus  … done
Pulling spark-one … done
Pulling redis     … done
Pulling traefik   … done
Pulling influx    … done
INFO       Starting services…
Creating brewblox_traefik_1   … done
Creating brewblox_redis_1     … done
Creating brewblox_ui_1        … done
Creating brewblox_influx_1    … done
Creating brewblox_spark-one_1 … done
Creating brewblox_history_1   … done
Creating brewblox_eventbus_1  … done
INFO       Migrating service configuration…
Connecting https://localhost:443/history/history/ping, attempt 1/60
Connecting https://localhost:443/history/history/ping, attempt 2/60
Connecting https://localhost:443/history/history/ping, attempt 3/60
Connecting https://localhost:443/history/history/ping, attempt 4/60
Connecting https://localhost:443/history/history/ping, attempt 5/60
Success!
INFO       Updating version number to 0.6.1…
INFO       Pruning unused images…
Total reclaimed space: 0B
INFO       Pruning unused volumes…
Deleted Volumes: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       Done!
pi@raspberrypi:~/brewblox $ brewblox-ctl update
612debd5ceeafec1ebd92bbc7579550ff33d3d2b9ba4677810c1ee5d1d0a0b74
ctl-lib
Stopping brewblox_ui_1        … done
Stopping brewblox_traefik_1   … done
Stopping brewblox_eventbus_1  … done
Stopping brewblox_spark-one_1 … done
Stopping brewblox_influx_1    … done
Stopping brewblox_history_1   … done
Stopping brewblox_redis_1     … done
Removing brewblox_ui_1        … done
Removing brewblox_traefik_1   … done
Removing brewblox_eventbus_1  … done
Removing brewblox_spark-one_1 … done
Removing brewblox_influx_1    … done
Removing brewblox_history_1   … done
Removing brewblox_redis_1     … done
Pulling ui        … done
Connecting https://localhost:443/history/history/ping, attempt 6/60
Success!
Deleted Volumes:
8c7c7ad5c31f8753a8d5c4f4f20cd784609d1a109e7faf99dd58546c0a456976
c188beda88f46ba0cec3a0d139c50cc39f4721f836e6bafddffe4dcf0fa8e753
