Hi
What is the best/recommended way to backup your Brewblox setup??
Do you need to backup both the raspberry and the spark??
Hi
brewblox-ctl backup save will backup everything except history data.
Hi
Will this just back it up to the SD card⦠I have had a few failing so trying to get a restore possibility??
Also, I the command just gives me an errorā¦
login as: pi
pi@192.168.10.207ās password:
Linux Brew_bloxs 4.19.42-v7+ #1219 SMP Tue May 14 21:20:58 BST 2019 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Mon Mar 2 19:58:21 2020 from 192.168.10.208
pi@Brew_bloxs:~ $ brewblox-ctl backup save
No such command ābackupā.
Many commands only work if your current directory is a BrewBlox directory.
It looks like you installed BrewBlox in the default location.
To navigate there, run:
cd /home/pi/brewblox
pi@Brew_bloxs:~ $ cd /home/pi/brewblox
pi@Brew_bloxs:~/brewblox $ brewblox-ctl backup save
Are you running the latest version? What is the output from brewblox-ctl help?
Hi
Brewblox-ctl help also failed⦠No such command ābackupā
But my guess is that the installation is at least 1 year oldā¦
From the interface i get:
Version
0.2.2+1176.g546b359d
Build date
Thu Oct 17 2019 12:24:34 GMT+0000 (Coordinated Universal Time)
If it helpsā¦
I was hoping to do a backup before updating the systemā¦
For a cruder, but still effective backup you can also copy and zip your brewblox dir.
I may have missed it, but it would be nice to have this backup function explained in Netlify, along with a newbie guide explaining how to transfer the .zip from the pi to a pc using ssh or perhaps sftp.
Sure. We avoided implementing an upload to cloud/other pc feature due to the lack of one-size-fits-all solutions, but I can add a guide describing some options.
What would be awesome is a similar backup function like the snapshot function found in homeassistant, if you are fammiliar with itā¦
Iām not very familiar with Home Assistent, but from their docs, their snapshots sound like our backups.
The functionality was added recently, and indeed isnāt present yet in your version.
One important concept in brewblox is that we keep all configuration contained in the install directory. Thatās why you can make a backup of your system by copying your brewblox directory.
The guide @r_vandenbroek requested is currently in review. Weāll probably publish it tomorrow.
Guide is live at https://brewblox.netlify.com/user/backup_guide.html
Feel free to let us know if you feel something is missing or unclear.
Fantastic and quick. Sure it will help people out there. One typo I spotted:
This will create a new zip archive in the backups/ directory inside your Brewblox directory. The file name includes the current date and time.
Should just be backup/ ofcourse.
Cheerio!
Hi
As the installation is old I tried to do an update without doing the backupā¦
No my smartest move i think⦠It seem like it has updated, but i have lost my configuration??
login as: pi
pi@192.168.10.134ās password:
Linux Brew_bloxs 4.19.42-v7+ #1219 SMP Tue May 14 21:20:58 BST 2019 armv7lThe programs included with the Debian GNU/Linux system are free software;
individual files in /usr/share/doc/*/copyright.Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
Last login: Sat Mar 7 09:51:21 2020 from 192.168.10.208
pi@Brew_bloxs:~ $ sudo raspi-config
login as: pi
Linux BrewBloxs 4.19.42-v7+ #1219 SMP Tue May 14 21:20:58 BST 2019 armv7lThe programs included with the Debian GNU/Linux system are free software;
Last login: Sat Mar 7 09:56:14 2020 from 192.168.10.208
pi@BrewBloxs:~ $ brewblox-ctl update
Usage: brewblox-ctl [OPTIONS] COMMAND [ARGS]ā¦
Try ābrewblox-ctl --helpā for help.Error: No such command āupdateā.
Many commands only work if your current directory is a Brewblox directory.
It looks like you installed Brewblox in the default location.
To navigate there, run:cd /home/pi/brewbloxpi@BrewBloxs:~ $ cd /home/pi/brewblox
pi@BrewBloxs:~/brewblox $ brewblox-ctl update
Do you want to remove old docker images to free disk space? [Y/n]: n
Command is about to: Download and apply updates.
Do you want to continue? (yes, no, verbose, dry-run) [press ENTER for default value āyesā]y
INFO Updating brewblox-ctlā¦
Requirement already up-to-date: brewblox-ctl in /usr/local/lib/python3.5/dist-packages
Requirement already up-to-date: requests in /usr/local/lib/python3.5/dist-packages (from brewblox-ctl)
Requirement already up-to-date: python-dotenv[cli] in /usr/local/lib/python3.5/dist-packages (from brewblox-ctl)
Requirement already up-to-date: pyyaml in /usr/local/lib/python3.5/dist-packages (from brewblox-ctl)
Requirement already up-to-date: click in /usr/local/lib/python3.5/dist-packages (from brewblox-ctl)
Requirement already up-to-date: pprint in /usr/local/lib/python3.5/dist-packages (from brewblox-ctl)
Requirement already up-to-date: urllib3!=1.25.0,!=1.25.1,<1.26,>=1.21.1 in /usr/local/lib/python3.5/dist-packages (from requests->brewblox-ctl)
Requirement already up-to-date: certifi>=2017.4.17 in /usr/local/lib/python3.5/dist-packages (from requests->brewblox-ctl)
Requirement already up-to-date: chardet<4,>=3.0.2 in /usr/local/lib/python3.5/dist-packages (from requests->brewblox-ctl)
Requirement already up-to-date: idna<3,>=2.5 in /usr/local/lib/python3.5/dist-packages (from requests->brewblox-ctl)
Digest: sha256:fe04e0d3823298a0f7bcf54e5e7baa7a8ccc3fb45ff886a6538b900781143ec3
Status: Image is up to date for brewblox/brewblox-ctl-lib:edge
69b7d7c43d20f74328a70958951da802538c58c4bca890302d6191b967fc3d1b
ctl-lib
INFO Stopping servicesā¦
Stopping brewblox_mdns_1 ⦠done
Stopping brewblox_traefik_1 ⦠done
Stopping brewblox_influx_1 ⦠done
Removing brewblox_eventbus_1 ⦠done
Removing brewblox_emitter_1 ⦠done
Removing brewblox_ui_1 ⦠done
Removing brewblox_history_1 ⦠done
Removing brewblox_datastore_1 ⦠done
Removing brewblox_mdns_1 ⦠done
Removing brewblox_traefik_1 ⦠done
Removing brewblox_influx_1 ⦠done
INFO Migrating configuration filesā¦
INFO Moving system services to docker-compose.shared.yml
INFO Writing env values for all variables
INFO Updating compose version to 3.7
INFO Pulling docker imagesā¦
Pulling emitter ⦠done
Pulling eventbus ⦠done
Pulling mdns ⦠done
Pulling ui ⦠done
Pulling history ⦠done
Pulling traefik ⦠done
Pulling influx ⦠done
Pulling datastore ⦠done
Pulling spark-one ⦠done
INFO Starting servicesā¦
Creating network ābrewblox_defaultā with the default driver
Creating brewblox_datastore_1 ā¦
Creating brewblox_influx_1 ā¦
Creating brewblox_traefik_1 ā¦
Creating brewblox_emitter_1 ā¦
Creating brewblox_ui_1 ā¦
Creating brewblox_eventbus_1 ā¦
Creating brewblox_mdns_1 ā¦
Creating brewblox_history_1 ā¦ERROR: for brewblox_emitter_1 UnixHTTPConnectionPool(host=ālocalhostā, port=None): Read timed out. (read timeout=60)
ERROR: for brewblox_mdns_1 UnixHTTPConnectionPool(host=ālocalhostā, port=None): Read timed out. (read timeout=60)
ERROR: for brewblox_history_1 UnixHTTPConnectionPool(host=ālocalhostā, port=NonCreating brewblox_influx_1 ⦠done
Creating brewblox_traefik_1 ⦠done
ERROR: for brewblox_eventbus_1 UnixHTTPConnectionPool(host=ālocalhostā, port=NoCreating brewblox_ui_1 ⦠doneERROR: for brewblox_datastore_1 UnixHTTPConnectionPool(host=ālocalhostā, port=None): Read timed out. (read timeout=60)
ERROR: for mdns UnixHTTPConnectionPool(host=ālocalhostā, port=None): Read timed out. (read timeout=60)
ERROR: for eventbus UnixHTTPConnectionPool(host=ālocalhostā, port=None): Read timed out. (read timeout=60)
ERROR: for history UnixHTTPConnectionPool(host=ālocalhostā, port=None): Read timed out. (read timeout=60)
ERROR: for datastore UnixHTTPConnectionPool(host=ālocalhostā, port=None): Read timed out. (read timeout=60)
ERROR: for emitter UnixHTTPConnectionPool(host=ālocalhostā, port=None): Read timed out. (read timeout=60)
ERROR: An HTTP request took too long to complete. Retry with --verbose to obtain debug information.
If you encounter this issue regularly because of slow network conditions, consider setting COMPOSE_HTTP_TIMEOUT to a higher value (current value: 60).
Command ādocker-compose up -d --remove-orphansā returned non-zero exit status 1
Command ā/usr/bin/python3 /usr/local/bin/brewblox-ctl update --update-ctl-done --no-pruneā returned non-zero exit status 1
Your configuration is still there.
These docker timeouts can have multiple causes, but you can likely fix it by running
brewblox-ctl down
sudo apt update
sudo apt upgrade -y
sudo reboot
When the pi is done rebooting, try running the update again.
I got it up and running again, took 4-5 attempts and it seemed to be a bit random what failed(timeout)ā¦
Thank you for the assistance
Docker pull timeout errors are always a bit tricky, as they are a symptom of something seemingly unrelated.
How much free space does your SD card have? (du -h)
How old / used is your SD card?
Are there leftover containers running? (docker ps -a)
Hi Bob,
I seem to be getting similar problem I did the brewblox-ctl down, update, upgrade and reboot and I still get the same problem. It seems to time out.
pi@raspberrypi:~/brewblox $ brewblox-ctl setup
INFO Starting configured services...
Creating network "brewblox_default" with the default driver
Creating brewblox_influx_1 ...
Creating brewblox_history_1 ...
Creating brewblox_traefik_1 ...
ERROR: for brewblox_history_1 UnixHTTPConnectionPool(host='localhost', port=None): Read timed out. (read timeout=60)
ERROR: for brewblox_influx_1 UnixHTTPConnectionPool(host='localhost', port=None): Read timed out. (read timeout=60)
ERROR: for brewblox_traefik_1 UnixHTTPConnectionPool(host='localhost', port=None): Read timed out. (read timeout=60)
ERROR: for history UnixHTTPConnectionPool(host='localhost', port=None): Read timed out. (read timeout=60)
ERROR: for influx UnixHTTPConnectionPool(host='localhost', port=None): Read timed out. (read timeout=60)
ERROR: for traefik UnixHTTPConnectionPool(host='localhost', port=None): Read timed out. (read timeout=60)
Command 'docker-compose up -d --remove-orphans traefik influx history' returned non-zero exit status 1.
pi@raspberrypi:~/brewblox $ du -h
du: cannot read directory './influxdb/data/_internal': Permission denied
4.0K ./influxdb/data/_internal
8.0K ./influxdb/data
du: cannot read directory './influxdb/wal': Permission denied
4.0K ./influxdb/wal
8.0K ./influxdb/meta
24K ./influxdb
4.0K ./couchdb
16K ./traefik
16K ./brewblox_ctl_lib/data/config
20K ./brewblox_ctl_lib/data
28K ./brewblox_ctl_lib/__pycache__
52K ./brewblox_ctl_lib/commands/__pycache__
108K ./brewblox_ctl_lib/commands
180K ./brewblox_ctl_lib
240K .
pi@raspberrypi:~/brewblox $ docker ps -a
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
461783b244ee brewblox/brewblox-history:edge "python3 -m brewbloxā¦" 3 minutes ago Created brewblox_history_1
69a2f8cb98a4 traefik:2.2 "/entrypoint.sh --apā¦" 3 minutes ago Up 44 seconds 0.0.0.0:80->80/tcp, 0.0.0.0:443->443/tcp brewblox_traefik_1
5c5bebe98a24 influxdb:1.8 "/entrypoint.sh inflā¦" 3 minutes ago Up 43 seconds 8086/tcp brewblox_influx_1
Can you run other docker containers?
docker run --rm hello-world
pi@raspberrypi:~/brewblox $ docker run --rm hello-world
Unable to find image āhello-world:latestā locally
latest: Pulling from library/hello-world
4ee5c797bcd7: Pull complete
Digest: sha256:7f0a9f93b4aa3022c3a4c147a449bf11e0941a1fd0bf4a8e6c9408b2600777c5
Status: Downloaded newer image for hello-world:latest
Hello from Docker!
This message shows that your installation appears to be working correctly.
To generate this message, Docker took the following steps:
To try something more ambitious, you can run an Ubuntu container with:
$ docker run -it ubuntu bash
Share images, automate workflows, and more with a free Docker ID:
https://hub.docker.com/
For more examples and ideas, visit:
https://docs.docker.com/get-started/
and there it stays. Is that it?
<pre><font color="#8AE234"><b>pi@raspberrypi</b></font>:<font color="#729FCF"><b>~/brewblox $</b></font> brewblox-ctl setup
<font color="#06989A">INFO Stopping services...</font>
Stopping brewblox_influx_1 ...
Stopping brewblox_history_1 ...
Stopping brewblox_traefik_1 ...
ERROR: for brewblox_history_1 UnixHTTPConnectionPool(host='localhost', port=None): Read timed out. (read timeout=70)
ERROR: for brewblox_traefik_1 UnixHTTPConnectionPool(host='localhost', port=None): Read timed out. (read timeout=70)
ERROR: for brewblox_influx_1 UnixHTTPConnectionPool(host='localhost', port=None): Read timed out. (read timeout=70)
<font color="#CC0000">ERROR</font>: An HTTP request took too long to complete. Retry with --verbose to obtain debug information.
Command 'docker-compose down --remove-orphans' returned non-zero exit status 1.</pre>
The hello-world output is normal.
Can you run sudo apt update && sudo apt upgrade -y, and then brewblox-ctl log?
