I just finished the assembly of my new setup and I am having an issue with my new ball valves (2- and 3-Piece full bore ball valves).
Fresh water flowing through the valves (Kettle & pump outlets) will exit them with a strange oil/plastic smell. The water still tastes normal, but the smell is well noticeable.
I rinsed the valves many times with cold water, hot water, oxy-clean and even sanitizer, without recognisable improvement.
Is there anyone with a good idea, how to solve the problem? How to properly clean the valves?
SS brewtech recommends Tri-Sodium-Phosphate (TSP) prior to first time use of their vessels, maybe that will help? Something that degreases well would be needed I think, because it is probably grease from the manufacturing process.
Have you tried disassembling them? Most (all?) ball valves have a cavity in them which the boar is open to in the closed position. It’s more or less impossible to deep clean them without taking them apart.
