Just updated to 0.4.4 and also updated the corresponding Tilt hydrometer mods.
Everything seemed to be working fine on 0.4.3.
I finished my Brew but accidentally over chilled the wort with my flat plate chiller and set the brewpi to 21˚C beer constant intending to create a profile this morning.
I was shocked to see it at 22˚C and still heating hence the flurry of changes after 10 am…
I have reset the photon back to defaults and re assigned devices and now put on a profile, which sat idling for 10 minutes but has now started to heat again even though the beer is 2˚c above set temperature…
I’ll just hang on till the fridge gets to it’s set point before I do anything else drastic.
.here are the control Algorithm settings
Controller state as JSON
Refresh
"kind": "Control",
"pids": [
"kind": "Pid",
"name": "heater1",
"enabled": true,
"setPoint": {
"kind": "SetPointSimple",
"name": "fridgeset",
"value": 18
"inputSensor": {
"kind": "TempSensorFallback",
"onBackupSensor": false,
"sensor": {
"kind": "TempSensor",
"name": "fridge",
"sensor": {
"kind": "OneWireTempSensor",
"value": 21.875,
"connected": true,
"address": "285C83B504000046",
"calibrationOffset": 0
"inputError": 3.875,
"Kp": 10,
"Ti": 600,
"Td": 60,
"p": -38.75,
"i": 0,
"d": 3.0859,
"actuatorIsNegative": false,
"outputActuator": {
"kind": "ActuatorPwm",
"value": 0,
"period": 4,
"minVal": 0,
"maxVal": 100,
"target": {
"mutexGroup": {
"kind": "ActuatorMutexGroup",
"deadTime": 1800000,
"waitTime": 1616513
"target": {
"kind": "ActuatorPin",
"state": false,
"pin": 10,
"invert": false
"kind": "Pid",
"name": "heater2",
"enabled": true,
"setPoint": {
"name": "beer2set",
"value": null
"inputSensor": {
"name": "beer2",
"sensor": {
"value": 12.5,
"connected": true,
"address": "28AA4C830400008A",
"inputError": null,
"Kp": 10,
"Ti": 600,
"Td": 60,
"p": 0,
"i": 0,
"d": 0,
"outputActuator": {
"value": 0,
"period": 4,
"minVal": 0,
"maxVal": 100,
"target": {
"mutexGroup": {
"waitTime": 1616511
"target": {
"kind": "ActuatorNop",
"state": false
"kind": "Pid",
"name": "cooler",
"enabled": true,
"setPoint": {
"value": 18
"inputSensor": {
"sensor": {
"name": "fridge",
"sensor": {
"value": 21.875,
"connected": true,
"Kp": 10,
"Ti": 1800,
"Td": 200,
"p": -38.75,
"i": 0,
"d": 10.1953,
"actuatorIsNegative": true,
"outputActuator": {
"value": 28.5547,
"period": 1200,
"minVal": 0,
"maxVal": 100,
"target": {
"mutexGroup": {
"waitTime": 1616508
"target": {
"minOnTime": 120,
"minOffTime": 180,
"maxOnTime": 65535,
"state": false,
"target": {
"state": false,
"pin": 11,
"invert": false
"kind": "Pid",
"name": "beer2fridge",
"enabled": false,
"setPoint": {
"name": "beer1set",
"value": null
"inputSensor": {
"name": "beer1",
"sensor": {
"value": 22.0625,
"connected": true,
"address": "28E95857040000CA",
"inputError": null,
"Kp": 2,
"Ti": 7200,
"Td": 1200,
"p": 0,
"i": 0,
"d": 0,
"outputActuator": {
"kind": "ActuatorSetPoint",
"targetSetPoint": {
"value": 18
"targetSensor": {
"name": "fridge",
"sensor": {
"value": 21.875,
"connected": true,
"referenceSetPoint": {
"name": "beer1set",
"value": null
"output": 127.9961,
"achieved": 127.9961,
"minimum": -10,
"maximum": 10
edit
changed the following to see how it behaves
Beer-to-Fridge proportional gain (Kp)= 8
Beer-to-Fridge integral time constant (Ti)=10200
Beer-to-Fridge derivative time constant (Td)=600
not sure but how feasible is it to incorporate a Tuning function to determine your initial PID settings
ie place a container with a known qty of liquid say 20 L, measure the time to raise it a set temperature then do the same to cool it and from that work out your PID variables…
