Sometime yesterday, while running a slow temperature ramp up in profile mode a number of things happened:
-beer temp probe stopped registering increases in temp
-beer set temp on the display stalled and stopped increasing with the profile target
-the graph stopped showing new data
-the heater apparently was running continuously
Concurrently the profile, as displayed in the lower window of the interface, continued to move along as programmed. As a result temperatures (over 12 hrs) got up to 110F inside the chamber and 95F beer temp all the while the display showed only the last known beer temp/ fridge temp and set points for both.
Unfortunately I didn’t notice this divergence until this morning. After a reboot, the actual temperatures began registering again but as you can see from the attached screen shot, it looks like there is no data between the short and the reboot as the graph shows just a solid line connecting the two points in time for beer temp/set point, fridge temp/set point, etc.
Anyone have an similar issue or any idea on what may have been the issue here? It seems now after rebooting that everything is working as it should.
This type of issue though makes me wonder if there is a way to create a stop order if certain conditions are not met, which might be an indicator that the script has stopped behaving as normal (like the logging of data, or the displayed set temp not matching the set temp on the profile)?
