Bootloader update for brewpi Spark v2 after years
Any ideas?
Brand new brewpi re-install on an RPi 4+
pi@brewblox:~/brewblox $ brewblox-ctl particle -c flash-bootloader
INFO Starting Particle image …
INFO Type ‘exit’ and press enter to exit the shell
edge: Pulling from brewblox/brewblox-firmware-flasher
Digest: sha256:3d96c6485d09c511c6828854fbe39c1b5bd2993727fd78457363d448c99497cc
Status: Image is up to date for Package brewblox-firmware-flasher · GitHub
Flashing Photon bootloader…
:::: NOTICE:
:::: Your first flash may take up to 10m to complete - during
:::: this time, your device may regularly change LED states
:::: as Device OS upgrades are applied.
NOTE: particle flash serial has been replaced by particle flash --local.
Please use that command going forward.
Error listing serial ports: spawn udevadm ENOENT
ERROR CalledProcessError(Command ‘docker run -it --rm --privileged -v /dev:/dev --pull always Package brewblox-firmware-flasher · GitHub flash-bootloader’ returned non-zero exit status 1.)
ERROR
Presumably you have followed the Spark 2 and 3 instructions here:
If so, then suggest trying discord as Elco responds much quicker there.
