I have flashed my BrewPi to the BrewBlox firmware as I need multi chamber control.(brew fridge and Keezer). Everything went fine.
My question is, when setting up the control blocks using the wizard and following the guide on the website, is there any particular order in which to create the control blocks. I have had a couple of attempts but when I view the layout it does not look anything like the layout on the website.
Many thanks for the quick response. I am getting to grips with it. I am trying to create the system detailed in the brewblox control chains documentation as this is what I want to achieve. My system is still on the bench so therefore I can play around without doing any damage to my brew. I can affect the beer temp by using cool water, but i can not seem to get it to go in heat mode, and conversely when I raise the temp it does not seem to want to go in cooling mode.
I have attached a screen grab of the relationships
Many thank once again. I am slowly getting to grips with it. I think I am expecting things to ripple through quickly when I alter the mock sensor input, but as you hightlighted there is a delay.
Another question if I may, the docs say set a negative value for the cooling PID, where about is this done?
If you edit the cool PID settings (cogwheel), you’ll see the “calculation” of the PID output. The wizard-generated PID is already configured: you’ll see the relevant negative values there.
I want to use the dynamic fridge configuration only but have the widgets from the fermentation wizardry install. Is it best to start from scratch and replicate the documentation on the site or to run the install and then modify?
If you have a straightforward fermenter (container in fridge or jacketed container, heater, cooler) I’d go with the default. It’s much simpler, and works well.
