brewbloxissue.txt (3.1 KB)
I’ve tried installing BrewBlox several times, but come back to the same issues. not sure what’s going on. I would like to automate the brewing/fermentation process and decided to give this a try. I have a raspberry pi 3 B+
There is a new version of the Raspberry Pi OS. Docker hasn’t yet updated its install script.
I’ve released a quick fix (thanks @j616s ) to brewblox- ctl. To update run sudo pip3 install -U brewblox-ctl
Afterwards you can run brewblox-ctl install
again.
still getting an errorbrewbloxissue2.txt (3.7 KB)
if you run curl -sL get.docker.com | sed 's/9)/10)/' | sh
manually, does that work?
brewbloxissue3.txt (266 Bytes)
doesn’t appear to.
Elco
July 7, 2019, 10:27am
6
Relevant issue:
The easiest workaround (if you don’t have a pi 4) would be to use raspbian stretch instead of buster.
Elco
July 7, 2019, 10:34am
7
As suggested in that thread:
sudo rm /etc/apt/sources.list.d/docker.list;
Or:
Edit /etc/apt/sources.list.d/docker.list
Change line to: deb [arch=armhf] https://download.docker.com/linux/raspbian stretch stable
the first solution worked.
thanks!
