brewbloxissue.txt (3.1 KB)
I’ve tried installing BrewBlox several times, but come back to the same issues. not sure what’s going on. I would like to automate the brewing/fermentation process and decided to give this a try. I have a raspberry pi 3 B+
There is a new version of the Raspberry Pi OS. Docker hasn’t yet updated its install script.
I’ve released a quick fix (thanks @j616s) to brewblox- ctl. To update run sudo pip3 install -U brewblox-ctl.
Afterwards you can run brewblox-ctl install again.
if you run curl -sL get.docker.com | sed 's/9)/10)/' | sh manually, does that work?
Relevant issue:
The easiest workaround (if you don’t have a pi 4) would be to use raspbian stretch instead of buster.
As suggested in that thread:
sudo rm /etc/apt/sources.list.d/docker.list;
Or:
deb [arch=armhf] https://download.docker.com/linux/raspbian stretch stable
the first solution worked.
thanks!
