Hi
Brewed last night and put the worth to fermenting at 17 degres. When I woke up and checked the temp the beer temp was 9 degres. somehow brewblox cooled down when it said it was heating. I remembered that I did a backup a couple of weeks ago so I restored the backup but now it doesnt work any more. Brewblox wont start and have some errors.
WARNING: Found orphan containers (brewblox_mdns-browser_1) for this project. If you removed or renamed this service in your compose file, you can run this command with the --remove-orphans flag to clean it up.
brewblox_spark-one_1 is up-to-date
Starting brewblox_ui_1 ...
Starting brewblox_eventbus_1 ...
Starting brewblox_traefik_1 ...
brewblox_history_1 is up-to-date
Starting brewblox_redis_1 ... error
Starting brewblox_victoria_1 ...
ERROR: for brewblox_redis_1 Cannot start service redis: AppArmor enabled on system but the docker-default profile could not be loaded: running `apparmor_parser apparmor_parser --version` failed with output:
Starting brewblox_victoria_1 ... error
Starting brewblox_eventbus_1 ... error
error: exec: "apparmor_parser": executable file not found in $PATH
Starting brewblox_ui_1 ... error
ERROR: for brewblox_eventbus_1 Cannot start service eventbus: AppArmor enabled on system but the docker-default profile could not be loaded: running `apparmor_parser apparmor_parser --version` failed with output:
ERROR: for brewblox_ui_1 Cannot start service ui: AppArmor enabled on system buStarting brewblox_traefik_1 ... error
ERROR: for brewblox_traefik_1 Cannot start service traefik: AppArmor enabled on system but the docker-default profile could not be loaded: running `apparmor_parser apparmor_parser --version` failed with output:
ERROR: for redis Cannot start service redis: AppArmor enabled on system but the docker-default profile could not be loaded: running `apparmor_parser apparmor_parser --version` failed with output:
ERROR: for victoria Cannot start service victoria: AppArmor enabled on system but the docker-default profile could not be loaded: running `apparmor_parser apparmor_parser --version` failed with output:
ERROR: for eventbus Cannot start service eventbus: AppArmor enabled on system but the docker-default profile could not be loaded: running `apparmor_parser apparmor_parser --version` failed with output:
ERROR: for ui Cannot start service ui: AppArmor enabled on system but the docker-default profile could not be loaded: running `apparmor_parser apparmor_parser --version` failed with output:
ERROR: for traefik Cannot start service traefik: AppArmor enabled on system but the docker-default profile could not be loaded: running `apparmor_parser apparmor_parser --version` failed with output:
Command 'docker-compose up -d ' returned non-zero exit status 1.
