Just decided to upgrade Raspberry Pi OS to Buster as suggested but the install process isn’t progressing as expected.
There’s something wrong when installing docker:
INFO Installing docker... # Executing docker install script, commit: 26ff363bcf3b3f5a00498ac43694bf1c7d9ce16c + sudo -E sh -c apt-get update -qq >/dev/null + sudo -E sh -c DEBIAN_FRONTEND=noninteractive apt-get install -y -qq apt-transport-https ca-certificates curl >/dev/null + sudo -E sh -c curl -fsSL "https://download.docker.com/linux/raspbian/gpg" | apt-key add -qq - >/dev/null Warning: apt-key output should not be parsed (stdout is not a terminal) + sudo -E sh -c echo "deb [arch=armhf] https://download.docker.com/linux/raspbian buster stable" > /etc/apt/sources.list.d/docker.list + sudo -E sh -c apt-get update -qq >/dev/null + [ -n ] + sudo -E sh -c apt-get install -y -qq --no-install-recommends docker-ce >/dev/null E: Sub-process /usr/bin/dpkg returned an error code (1) Command 'curl -sL get.docker.com | sh' returned non-zero exit status 100.
Docker Service status:
Oct 27 20:23:10 raspberrypi systemd[1]: docker.service: Service RestartSec=2s expired, scheduling restart. Oct 27 20:23:10 raspberrypi systemd[1]: docker.service: Scheduled restart job, restart counter is at 4. Oct 27 20:23:10 raspberrypi systemd[1]: Stopped Docker Application Container Engine. Oct 27 20:23:10 raspberrypi systemd[1]: **docker.service: Start request repeated too quickly.** Oct 27 20:23:10 raspberrypi systemd[1]: **docker.service: Failed with result 'exit-code'.** Oct 27 20:23:10 raspberrypi systemd[1]: **Failed to start Docker Application Container Engine.**
Journal ($ journalctl -xe)
-- The job identifier is 2383. Oct 27 20:23:10 raspberrypi systemd[1]: Listening on Docker Socket for the API. -- Subject: A start job for unit docker.socket has finished successfully -- Defined-By: systemd -- Support: https://www.debian.org/support -- -- A start job for unit docker.socket has finished successfully. -- -- The job identifier is 2383. Oct 27 20:23:10 raspberrypi systemd[1]: docker.service: Start request repeated too quickly. Oct 27 20:23:10 raspberrypi systemd[1]: docker.service: Failed with result 'exit-code'. -- Subject: Unit failed -- Defined-By: systemd -- Support: https://www.debian.org/support -- -- The unit docker.service has entered the 'failed' state with result 'exit-code'. Oct 27 20:23:10 raspberrypi systemd[1]: Failed to start Docker Application Container Engine. -- Subject: A start job for unit docker.service has failed -- Defined-By: systemd -- Support: https://www.debian.org/support -- -- A start job for unit docker.service has finished with a failure. -- -- The job identifier is 2320 and the job result is failed. Oct 27 20:23:10 raspberrypi systemd[1]: docker.socket: Failed with result 'service-start-limit-hit'. -- Subject: Unit failed -- Defined-By: systemd -- Support: https://www.debian.org/support -- -- The unit docker.socket has entered the 'failed' state with result 'service-start-limit-hit'.
