Relevant links:
Brewblox release 2020/10/19
firmware release date: 2020/10/11
brewblox-ctl uses Python. Python 3.5, the default version for Raspbian Stretch, was discontinued in september. Raspbian does not support upgrading Python versions.
If you are not yet running the latest Raspbian (Buster), we strongly recommend re-flashing your SD card.
For those unsure of which Raspbian version theyâre using: brewblox-ctl will warn you if your Python version is unsupported.
brewblox-ctl still works on Raspbian Stretch, but depends on other software projects that have announced they will soon no longer be compatible with Python 3.5.
We added commands to brewblox-ctl to make it easy to move your Brewblox installation without losing any settings or history data.
For more information, see our system upgrade guide.
The PWM block has also received a minor rework, both in firmware, and in the UI.
In the firmware, we fixed an issue where the PWM overcompensated for setting changes after it had spent a long period at either 0% or 100%.
In the UI, we reworked the widget to improve visibility of desired setting, actual setting, and achieved value.
We also added a slider to the Basic version of the widget, making it much easier to control.
In response to this thread, we created an experimental service for sharing data with Home Assistant.
It will be some time before we find the time to significantly extend this service, but the concept is promising.
Changes
- (docs) Added system upgrade guide.
- (docs) Added service architecture doc.
- (feature) Added the
brewblox-ctl init
command. This creates a brewblox dir. It is also part ofbrewblox-ctl install
. - (feature) Added the
brewblox-ctl snapshot save
command. This zips the entire brewblox dir. It is more complete, but also takes much more space thanbrewblox-ctl backup save
brewblox-ctl snapshot load
command. This restores snapshots created bybrewblox-ctl snapshot save
. You can also usebrewblox-ctl install --snapshot ARCHIVE
. - (improve)
brewblox-ctl
now shows a warning if the Python version is unsupported (currently 3.5 or earlier). - (feature) Added the Stopwatch widget.
- (improve) Reworked the PWM widget.
- Desired setting is now set by using a slider.
- It clearly shows when the PWM is driven, and setting canât be set manually.
- Improved rendering of desired setting, actual setting, and achieved value.
- (feature) Added the brewblox-hass service as proof of concept for Home Assistant integration.
- (improve) Reworked discover/connect behavior in the Spark service to reboot the service less frequently.
- (improve) Invalid
command
arguments in services now generate a warning, but do not immediately cause the service to exit. - (improve) The UI now shows the Spark Troubleshooter if the service is running, but does not respond to status requests.
- (improve) The Spark Troubleshooter now shows whether a firmware update is in progress.
- (improve) Increased brightness for some text elements on the Spark display screen.
- (improve) System objects with no persistent data are no longer stored in persistent memory.
- (fix) Possibly fixed a bug where the UI would show its âwaiting for datastoreâ notification even when the datastore already is available.
- Weâre not sure about this one, as we couldnât consistently reproduce the error.
- (fix) The PWM no longer overcompensates for setting changes after spending a long time at 0% or 100%.
- (fix) If changing block settings would cause the Spark to run out of persistent memory, the old block settings are retained.
