Relevant links:
- Discord server: Brewblox
- Previous release notes: Brewblox release notes | Brewblox
- Project board: BrewBlox · GitHub
- Code repositories: BrewBlox · GitHub
Brewblox release 2021/08/09
firmware release date: 2021-05-27
This is a minor bugfix release as follow-up to the 2021/08/02 release.
Changes:
- (improve) Slightly reduced memory usage for
brewblox-ctl database from-influxdb - (improve) Improved efficiency when polling the Spark for history/state data.
- (fix) Widgets can no longer exceed screen width on mobile devices.
- (fix) Date to now mode for graphs no longer fails to yield data.
- (fix) The PWM duty setting field in the Quick Actions widget no longer immediately resets values.
Brewblox release 2021/08/02
Our planning has been upset somewhat lately, with Elco taking parental leave a lot earlier than expected.
To compensate, we’ve shifted a non-firmware task forward: the replacement of our history database.
New history database
InfluxDB announced that they will drop support for 32-bit architectures on 1/1/2022.
This is a deal-breaker for us, as Raspberry Pi OS has a 32-bit architecture.
We decided to go with Victoria Metrics as replacement, as it had the best combination of features and small CPU/RAM/disk footprint. For a more detailed explanation, you can find the decision document here.
Database migrations are always a big step, but we’re pretty happy with this one. Broadly speaking, it’s twice as fast, and uses half the memory.
Where the InfluxDB data required some custom handling, the Victoria Metrics model is much simpler.
It’s simple enough that you can add a Grafana service, and have it work as expected out of the box.
Your system will be immediately functional after updating, and will log data into Victoria Metrics. Older data will have to be copied from InfluxDB to Victoria.
For this, we made a data migration command
You can run the migrate command in the background. Depending on how much data you have, the migration takes minutes to hours.
Migrations can safely be stopped and restarted or resumed.
After the migration is done, you’ll still have all your old history data in the brewblox/influxdb/ directory.
Tilt Service
James Sandford’s brewblox-tilt service has been very popular for some years now, and we’ve decided to make it official.
James was happy for us to take over development and maintenance, so we forked his service.
The new service comes with support for the Tilt Pro.
You can install the new Tilt service by running brewblox-ctl add-tilt -f.
Graphical config editor
For common configuration changes, we add commands to brewblox-ctl.
You’ll still sometimes have to edit the configuration files themselves.
Terminal text editors have a pretty steep learning curve, but by now the Remote - SSH plugin for Visual Studio Code is stable enough that we’re happy recommending it.
This way you read and edit text files from the comfort of your own computer.
You can find the install guide here.
Changes:
- (feature) Changed history database from InfluxDB to Victoria Metrics.
- (feature) Added
/victoriaendpoint./victoria/api/v1is compatible with the Prometheus HTTP API. - (feature) Added
/history/timeseriesendpoints. For an overview, see/history/api/doc - (feature) The “hide after” period for Graph and Metrics fields is now customizable. The default is still 1d.
- (feature) The maximized Graph widget is now a separate page with its own URL.
- Refreshing the page will no longer close the graph.
- You can bookmark the page to instantly visit the maximized graph.
- (feature) We now maintain the Tilt service.
- (feature) The Tilt service now supports the Tilt Pro.
- (feature) Added
brewblox-ctl add-tilt. - (feature) Added
brewblox-ctl database from-couchdbcommand. - (feature) Added
brewblox-ctl database from-influxdbcommand. - (docs) Added user guide for VSCode with SSH Remote plugin.
- (docs) Updated Troubleshooting guide.
- (docs) Added Grafana service install guide.
- (docs) Documented advanced usage of
brewblox-ctl database from-influxdb. - (improve) Added Apple PWA headers to the UI.
- (improve)
brewblox-ctl service removeno longer requires the-n/--nameoption for services, and can remove multiple services at once.- OLD:
brewblox-ctl service remove -n spark-one. - NEW:
brewblox-ctl service remove spark-one.
- OLD:
- (deprecation) Removed the
brewblox-ctl service editorcommand. - (deprecation) Removed
/history/historyendpoints. - (fix) The side pane graph in block widgets now correctly re-renders when the duration is changed.
- (fix) The builder layout is now always correctly centered when opening the widget dialog.
