desiredSetting and setting should both exist on a setpoint block. Which of these are still available on your setpoints?
Could you please open the enclosure, and take a picture of the top connector block? You could also try switching to soft start 100Hz, but I indeed suspect that if they read a steady 1V, they’re indeed broken. I’ll need Elco to confirm it though.
The top 1 and top 2 pins use a different IO driver, one that is bidirectional, so they can also be used as input. I think the direction pin is not properly set, so hopefully it is a software bug that I can resolve tomorrow.
OK Setting magically appeared back in the list sometime while I was making dinner. Just a hunch, wondering if you have a timezone issue there. I’ve been working with industrial historians for 25 years, when something like that happens the very first thing I check is that there’s not a timezone issue somewhere in the system!
I did open the enclosure. I don’t see any issues mechanically, plus its all one header so losing 2 of 3 seems suspect.
Good morning
I have just run update again after problems with top pins 1 & 2 - Now I just get a blank screen and flashing red light on Spark 3. Any ideas
Could you please post the PID graphs for your cooler and heater? Those will also include the built-up integrator, which is reset during restarts (and thus updates).
I realized what happened: bottom pins got inverted. The Spark 2 was cooling the keggerator instead of the ferm chamber.
For some reason, setting the Bottom 3 pin actuator actually changes Bottom 2. And by setting the Bottom 2 Pin you actually change the Bottom 1.
After removing all the blocks and running the fermentation Wizard several times and manually choosing the pin actuator I think I got everything sorted out again.
@Elco, that sounds like a off-by-one error somewhere in channel handling.
This happened to come up a few days ago as well. We agree, but we may want to roll it into a rework of various quick start wizards. Right now there’s a lot of code duplication and somewhat fragile configuration.
