Relevant links:
Brewblox release 2023/01/26
firmware release date: 2023-01-27
After some technical tweaks, we can now properly render graphs in Builder layouts - without the graph being reloaded when a neighboring valve opens.
As an added bonus, copy / cut / paste keyboard shortcuts are now supported in the Builder editor.
You can also use this to copy or move parts between layouts.
Changes
- (feature) Added the
Display: GraphBuilder part. - (feature) Added the
Display: iframeBuilder part. - (feature) Copy / cut / paste keyboards shortcuts are now supported in the Builder editor.
- (improve) The Builder is now much more precise in determining what parts should be re-rendered when settings are changed.
- (improve) The “Import layout” and “New layout” actions are now shown in more locations.
- (improve) The Sequence line parser now raises an error when a delta temperature value is used in an absolute temperature field, and vice versa.
- (improve) When picking up Builder parts, the cursor is now centered instead of in the top-left square.
- (docs) Removed obsolete sections from Tilt service documentation.
- (fix) Resolved an issue where the Spark service would fail to parse some blocks when generating backups.
- (fix) Blocks now immediately unclaim their target when disabled in a Sequence instruction.
- (fix) The UI no longer redirects to a 404 page when removing the current Builder layout.
