Relevant links:
Brewblox release 2023/01/17
firmware release date: 2024/01/03
Authentication
By default, Brewblox is only accessible from inside your local network.
If you want to use the UI when away from home, it must be secured.
The safest and most comprehensive way to do this is by setting up a Virtual Private Network (VPN).
This way, you can connect to the local network even when away from home.
The downside to this is that configuration is relatively complicated, and it must be set up for every device.
In this release, we’ve added an alternative: password authentication for all public API access.
With this, you can safely expose the Brewblox UI to the internet.
Authentication is not enabled by default. If you want to continue using Brewblox inside your local network only, we’re not going to annoy you with mandatory login pages.
To enable it, run:
brewblox-ctl auth enable
This will prompt you to add a user, and will then enable the service that checks all incoming HTTP requests.
SSL Certificates and Authorities
HTTPS connections are secured using SSL certificates. If you have a public website, you can create a certificate, and then ask a Certificate Authority (CA) to sign it.
When signed, it will be trusted by browsers.
SSL Certificates are valid only for a specific domain. When you ask a CA to sign a certificate for www.example.com, the CA first checks that you actually control www.example.com.
We expect Brewblox to be hosted locally. If you can’t access the Brewblox UI from outside your local network, a CA can’t either.
If we can’t get a public CA to sign our SSL certificate, the alternative is to have a self-signed certificate.
When browsers encounter a self-signed SSL certificate, they don’t trust it, and will show a warning page first.
On iOS devices, graphs in the UI won’t work even after clicking through the warning page.
To fix these issues, we now create a new and unique self-signed CA certificate when installing Brewblox,
and use that to sign the certificates used by the UI and the REST API.
By default, this changes very little. You have to click through a slightly different error message when accessing the UI.
If you want to use the UI without the error page, or have an iOS device, you can choose to install the self-signed CA certificate on your device.
Your browser will then trust the UI certificate without any further prompting.
To do this:
- Navigate to the Brewblox UI
- Click continue when shown the certificate warning page
- Go to “Admin”
- Expand “General Settings”
- Click on “Install SSL Cert”
- Follow the instructions for your browser or device
Changes
- (feature) The UI redirects HTTP to HTTPS. iOS users should import the CA certificate to prevent Websocket-related problems.
- (feature) Brewblox now uses a self-signed CA to sign its SSL certificate. You can import the CA certificate to prevent browser warnings.
- (feature) Added an instruction dialog for importing the Brewblox CA certificate.
- (feature) The Tilt service can now share the Bluetooth adapter.
- (improve) Significantly improved performance of the history csv endpoint.
- (feature) Added optional authentication support. Enable it by running
brewblox-ctl auth enable. - (feature) Added a login screen to the UI if authentication is enabled.
- (feature) Added relations diagrams for blocks with meaningful links.
- (improve) The Spark service is more intelligent about when it needs to restart if it can’t discover a Spark.
- (improve) Improved error handling for invalid widgets. They will no longer block other widgets.
- (fix) The Spark service returns an error object if it can’t decode a block sent by the Spark.
- (fix) The history csv endpoint can no longer yield duplicate points.
- (fix) The UI now always checks whether itself was updated.
- (fix) The SysInfo block now shows the correct values for memory usage.
- (fix) Fixed behavior for multiple UI input fields if a value is not set.
- (fix) The PID relations diagram no longer causes an error.
- (fix) The Metrics widget now correctly shows older values.
- (fix) The duration shortcuts in the maximized Graph window work again.
- (fix) The duration shortcuts in the block widget sidepanel work again.
- (fix) Prevented bogus Open Load errors for mechanical relays and bidirectional motors.
- (fix) Fixed a buffer overflow when reading many / large blocks on the Spark 4.
- (fix) Fixed a stack overflow in Spark MQTT communication.
- (fix) PID integrator values are now correctly read from cache after controller restart.
- (docs) Added developer documentation for setting up a Python virtualenv.
- (dev) Added a admin port (default
9600). This is a non-authenticated HTTP port that is only accessible from the server itself.
