Relevant links:
- Project board: https://github.com/orgs/BrewBlox/projects/2/views/1
Brewblox release 2024/07/19
firmware release 2024/07/08
This is the customary smaller follow-up release after the dust from a larger update has settled.
Included are various small QoL improvements.
Changes
- (feature) You can now set a custom duration in block graphs, in addition to the existing preset options.
- (feature) Added the Valve: three way part to the Builder. This is a manually operated T-bore three-way valve.
- (feature) PID boil mode minimum output can now be set through a quick action.
brewblox-ctl monitorcommand. This will show log output for a Spark 4 connected over USB. - (improve) Added 4h and 12h to graph presets.
- (improve) brewblox-ctl now always uses curl for HTTP requests executed as shell command.
- (improve) reflector services now periodically retry if the network interface was initially disconnected.
- (fix) Sensors and actuators are now created correctly when loading a backup made on a different model Spark.
- (deprecate) Removed the hidden
brewblox-ctl httpcommand group.
