Brewblox release 2024/10/08
Relevant links:
firmware release 2024/10/07
Firmware in the previous release was actually reverted tot 2024/07/08 due to an critical bug just before our holiday.
The PID fix to limit the impact of D on anti-windup is included in this release.
Changes
  • (feature) You can set a min/max on graph fields to hide outliers
  • (improve) Improved reliability of USB flashing for Spark 2 and Spark 3.
  • (fix) Toggling the enabled field for a spark service (auto connect) was stored not immediately applied
  • (fix) Comments in a sequence caused encoding errors
  • (fix) Channel H of the mock pins block didn’t have the right error state
  • (fix) Claimer id was truncated to 16-bit causing the driver of a block to not be displayed correctly
