I’m moving over from brewpi to brewblox and I’m trying to get brewblox to get my beer temp to be close to my beer setting. Currently, the beer temp is +8F from my beer setting (I’ve seen it be as close as +2F).
I have a 7 cubic foot chest freezer and a 25W heater that are controlled by the Spark 3 with solid state relays.
When I was using the BrewPi software, it was very good at keeping the beer temp very close to my beer setting.
I’m using a Ferment Temp Profile to keep the beer at 35F.
What changes should I make to get my beer temp closer to my desired setting?
I was thinking of increasing the Kp from -5.5F to -8F and the Ti from 2h to 1h. Thoughts?
It looks like your Spark is rebooting rather often. We had some issues with the Wifi stack a few weeks back. If you clear the Wifi credentials, and connect over USB, does the problem persist?
How do I clear the wifi credentials? When I go to Service -> Action -> Wifi, there aren’t any settings to clear. When I run brewblox-ctl wifi, I get stuck at the SSID prompt:
grant@raspberrypi:~/brewblox $ brewblox-ctl wifi
docker-compose down
docker pull brewblox/firmware-flasher:rpi-edge
docker run -it --rm --privileged brewblox/firmware-flasher:rpi-edge wifi
Digest: sha256:af25abef814f1a512a41a7fbca4c03832bf7eed721a07c90b6785f613d3b5df6
Running command:
Important: Select no when asked to scan for Wi-Fi networks
? Should I scan for nearby Wi-Fi networks? No
? SSID
Well, darn. Things were going so well there for a few hours. The beer was actually being cooled down to 35F. Now the spark is rebooting every minute or so (I can hear the beep).
Attaching spark-one service view, json log and brewblox.log
The reset reason given by the spark is a watchdog reset: no control loop being run for 60s, which triggers a reset by design.
What is on the display and what is the color and pattern of the LED? Could something be pressing on the display holding it in the display calibration routine?
I don’t think this is WiFi related.
I have some troubles with settings for my setup as well.
My setup is a HERMS with 3 pans of 50 Liters. I would like to start testing with my HERMS setup but I have no clue with what settings to start. Can anybody help me out with some settings that give me a good start?
Besides that I am test running with barrel of water in my fridge for fermeting. I used the default settings from the fermenting fridge wizzard. I have some under and overshoot. So some finetuning is necessary. Any tips on what setting to change?
screenshot of testrun in fridge with default settings:
The PID block has a preset for the HLT (HLT Setpoint Driver) and the MT/BK (Kettle heating element). You can find the presets under the actions dropdown in the PID widget -> block actions.
