Brewblox update error
I tired to update my brewblox software and I kept getting a weird error: “error pulling image configuration”. So I just decided to remove and reinstall brewblox. The install went well but when I tried to run “brewblox-ctl setup” I get the same error I was getting at first:
"pi@raspberrypi:~/brewblox $ brewblox-ctl update
brewblox-ctl requires extensions that match your Brewblox release. Do you want to download them now? [Press ENTER for default value ‘yes’]
y
SHELL docker rm ctl-lib
SHELL docker pull brewblox/brewblox-ctl-lib:edge
6e1a744202a5: Pulling fs layer
error pulling image configuration: Get https://production.cloudflare.docker.com/registry-v2/docker/registry/v2/blobs/sha256/c0/c0c0f2470776c75c4237f5b4bfdb73f6ae71dedf2c622e4da2d533695ce2320f/data?verify=1610918724-jdr4f2Ys2dokV1mVmEI8mQLPHTs%3D: dial tcp 104.18.123.25:443: i/o timeout
Error: Command ‘docker pull brewblox/brewblox-ctl-lib:edge’ returned non-zero exit status 1."
Any idea what’s going on?
For the vast majority of errors, reinstalling is a bit overkill =)
This error means the servers over at Docker are having some (temporary) problems. It should work when you retry in a bit. If it doesn’t, we’ll have a look at a workaround to force the download to use another of their servers.
