Attempting to install the latest update by using ‘brewblox-ctl update’ … at the end I get:
Installing collected packages: brewblox-ctl, docker-compose
The script brewblox-ctl is installed in ‘/home/pi/.local/bin’ which is not on PATH.
Consider adding this directory to PATH or, if you prefer to suppress this warning, use --no-warn-script-location.
The script docker-compose is installed in ‘/home/pi/.local/bin’ which is not on PATH.
Successfully installed brewblox-ctl-0.21.0 docker-compose-1.25.5
INFO Please run source ~/.profile and restart the update
pi@RampantPi4:~/brewblox $ source ~/.profile
So I ran “source ~/.profile” as instructed and now seem to have broken the path to finding ‘brewblox-ctl’
pi@RampantPi4:~/brewblox $ sudo brewblox-ctl update
sudo: brewblox-ctl: command not found
pi@RampantPi4:~/brewblox $ ls
brewblox_ctl_lib docker-compose.shared.yml influxdb
couchdb docker-compose.yml traefik
A trivial question if I took the time to work it out for myself but this is a fresh installation about a week old and this is the first update so there hopefully will be something useful in it for someone else.
Hopefully.
Thanks - keep well everyone,
A.
