Good day All,
I am having a problem when installing BrewBlox on a raspberry Pi. I am following the guide of the website, however when I issue the command brewblox-ctl install to start the process off, all appear to go well until it reaches the line "Building wheels for collected packages: Cryptography.
At this point the install script stalls with the error "
I have included the output from the terminal in a hope that you may be able to point out my error
build/temp.linux-armv7l-3.5/_openssl.c:498:30: fatal error: openssl/opensslv.h: No such file or directory
#include <openssl/opensslv.h>
compilation terminated.
error: command âarm-linux-gnueabihf-gccâ failed with exit status 1
Failed building wheel for cryptography
Running setup.py clean for cryptography
Failed to build cryptography
Installing collected packages: texttable, pynacl, pyasn1, bcrypt, cryptography, paramiko, docker, docker-compose
Found existing installation: pyasn1 0.1.9
Not uninstalling pyasn1 at /usr/lib/python3/dist-packages, outside environment /usr
Found existing installation: cryptography 1.7.1
Not uninstalling cryptography at /usr/lib/python3/dist-packages, outside environment /usr
Running setup.py install for cryptography ⌠error
Complete output from command /usr/bin/python3 -u -c âimport setuptools, tokenize;file=â/tmp/pip-build-vt88aznd/cryptography/setup.pyâ;f=getattr(tokenize, âopenâ, open)(file);code=f.read().replace(â\r\nâ, â\nâ);f.close();exec(compile(code, file, âexecâ))â install --record /tmp/pip-kffu7a7l-record/install-record.txt --single-version-externally-managed --compile:
running install
running build
running build_py
creating build
creating build/lib.linux-armv7l-3.5
creating build/lib.linux-armv7l-3.5/cryptography
copying src/cryptography/about.py -> build/lib.linux-armv7l-3.5/cryptography
copying src/cryptography/init.py -> build/lib.linux-armv7l-3.5/cryptography
copying src/cryptography/fernet.py -> build/lib.linux-armv7l-3.5/cryptography
copying src/cryptography/exceptions.py -> build/lib.linux-armv7l-3.5/cryptography
copying src/cryptography/utils.py -> build/lib.linux-armv7l-3.5/cryptography
creating build/lib.linux-armv7l-3.5/cryptography/hazmat
copying src/cryptography/hazmat/_oid.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat
copying src/cryptography/hazmat/init.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat
creating build/lib.linux-armv7l-3.5/cryptography/x509
copying src/cryptography/x509/oid.py -> build/lib.linux-armv7l-3.5/cryptography/x509
copying src/cryptography/x509/general_name.py -> build/lib.linux-armv7l-3.5/cryptography/x509
copying src/cryptography/x509/base.py -> build/lib.linux-armv7l-3.5/cryptography/x509
copying src/cryptography/x509/extensions.py -> build/lib.linux-armv7l-3.5/cryptography/x509
copying src/cryptography/x509/certificate_transparency.py -> build/lib.linux-armv7l-3.5/cryptography/x509
copying src/cryptography/x509/init.py -> build/lib.linux-armv7l-3.5/cryptography/x509
copying src/cryptography/x509/name.py -> build/lib.linux-armv7l-3.5/cryptography/x509
copying src/cryptography/x509/ocsp.py -> build/lib.linux-armv7l-3.5/cryptography/x509
creating build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/padding.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/constant_time.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/hashes.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/mac.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/init.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/cmac.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/hmac.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/keywrap.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives
creating build/lib.linux-armv7l-3.5/cryptography/hazmat/backends
copying src/cryptography/hazmat/backends/init.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends
copying src/cryptography/hazmat/backends/interfaces.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends
creating build/lib.linux-armv7l-3.5/cryptography/hazmat/bindings
copying src/cryptography/hazmat/bindings/init.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/bindings
creating build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/twofactor
copying src/cryptography/hazmat/primitives/twofactor/init.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/twofactor
copying src/cryptography/hazmat/primitives/twofactor/hotp.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/twofactor
copying src/cryptography/hazmat/primitives/twofactor/utils.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/twofactor
copying src/cryptography/hazmat/primitives/twofactor/totp.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/twofactor
creating build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/padding.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/x25519.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/ed448.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/ec.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/init.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/dh.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/x448.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/ed25519.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/utils.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/dsa.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/rsa.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/asymmetric
creating build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/serialization
copying src/cryptography/hazmat/primitives/serialization/pkcs12.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/serialization
copying src/cryptography/hazmat/primitives/serialization/base.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/serialization
copying src/cryptography/hazmat/primitives/serialization/init.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/serialization
copying src/cryptography/hazmat/primitives/serialization/ssh.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/serialization
creating build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/ciphers
copying src/cryptography/hazmat/primitives/ciphers/base.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/ciphers
copying src/cryptography/hazmat/primitives/ciphers/init.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/ciphers
copying src/cryptography/hazmat/primitives/ciphers/aead.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/ciphers
copying src/cryptography/hazmat/primitives/ciphers/algorithms.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/ciphers
copying src/cryptography/hazmat/primitives/ciphers/modes.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/ciphers
creating build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/kdf
copying src/cryptography/hazmat/primitives/kdf/scrypt.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/kdf
copying src/cryptography/hazmat/primitives/kdf/x963kdf.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/kdf
copying src/cryptography/hazmat/primitives/kdf/hkdf.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/kdf
copying src/cryptography/hazmat/primitives/kdf/init.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/kdf
copying src/cryptography/hazmat/primitives/kdf/pbkdf2.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/kdf
copying src/cryptography/hazmat/primitives/kdf/concatkdf.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/kdf
copying src/cryptography/hazmat/primitives/kdf/kbkdf.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/kdf
creating build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/decode_asn1.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/x25519.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/hashes.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/ed448.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/ciphers.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/ec.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/init.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/aead.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/x509.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/encode_asn1.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/cmac.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/dh.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/hmac.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/x448.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/ocsp.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/ed25519.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/backend.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/utils.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/dsa.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/rsa.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
creating build/lib.linux-armv7l-3.5/cryptography/hazmat/bindings/openssl
copying src/cryptography/hazmat/bindings/openssl/_conditional.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/bindings/openssl
copying src/cryptography/hazmat/bindings/openssl/init.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/bindings/openssl
copying src/cryptography/hazmat/bindings/openssl/binding.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/bindings/openssl
running egg_info
writing dependency_links to src/cryptography.egg-info/dependency_links.txt
writing top-level names to src/cryptography.egg-info/top_level.txt
writing requirements to src/cryptography.egg-info/requires.txt
writing src/cryptography.egg-info/PKG-INFO
reading manifest file âsrc/cryptography.egg-info/SOURCES.txtâ
reading manifest template âMANIFEST.inâ
no previously-included directories found matching âdocs/_buildâ
warning: no previously-included files matching â*â found under directory âvectorsâ
writing manifest file âsrc/cryptography.egg-info/SOURCES.txtâ
running build_ext
generating cffi module âbuild/temp.linux-armv7l-3.5/_padding.câ
creating build/temp.linux-armv7l-3.5
generating cffi module âbuild/temp.linux-armv7l-3.5/_constant_time.câ
generating cffi module âbuild/temp.linux-armv7l-3.5/_openssl.câ
building â_opensslâ extension
creating build/temp.linux-armv7l-3.5/build
creating build/temp.linux-armv7l-3.5/build/temp.linux-armv7l-3.5
arm-linux-gnueabihf-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -g -fdebug-prefix-map=/build/python3.5-6waWnr/python3.5-3.5.3=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I/usr/include/python3.5m -c build/temp.linux-armv7l-3.5/_openssl.c -o build/temp.linux-armv7l-3.5/build/temp.linux-armv7l-3.5/_openssl.o -Wconversion -Wno-error=sign-conversion
Canât rollback cryptography, nothing uninstalled.
Command â/usr/bin/python3 -u -c âimport setuptools, tokenize;file=â/tmp/pip-build-vt88aznd/cryptography/setup.pyâ;f=getattr(tokenize, âopenâ, open)(file);code=f.read().replace(â\r\nâ, â\nâ);f.close();exec(compile(code, file, âexecâ))â install --record /tmp/pip-kffu7a7l-record/install-record.txt --single-version-externally-managed --compileâ failed with error code 1 in /tmp/pip-build-vt88aznd/cryptography/
Error: Command âsudo /usr/bin/python3 -m pip install -U docker-composeâ returned non-zero exit status 1
pi@raspberrypi:~ $
Sorry if this is a bit messy but I could not see another way of doing it.
Regards
