Hi @desmop, if you are using an arduino you do have to run the sudo ~/brewpi-tools/updater.py --ask command and set it back to legacy branch. [4].
Did you have the brewpi running prior to attempting this integration?
This is an issue others have brought up back in Feb. Have you looked back at earlier posts. Here is one that may help you. Brewometer integration
I would suggest that you first install the legacy version of brewpi as the error message instructs. verify that works before making any alterations. Then when thats working make the modifications for the tilt hydrometer integration.
Thanks Ron_K for the help. Everything was working fine before the integration of the âTiltâ file changes. I kept getting the brewpi log error that my version 0.2.10 was not compatible with the new 0.4.0 version script so it would halt. I had to wipe out /home/brewpi and www/var doing a complete refresh. Not sure Iâm going to try it again. Thanks for the help.
I also use the arduino version. Instead of following SBowlers instructions for the spark version, I found This repository that forked off of the original version, written for the arduino. have you tried this? https://github.com/supercow/brewpi-brewometer
Thanks Ron, I will try this repository. Iâll keep you posted on the progress.
I followed the guide and installed everything. Given file permissions.
With test option I see the Tilt.
I can not, however, make the log on brewpi in graphical interface. You can not see anything.
In the log i have this error. What should I do?
May 06 2017 16:51:50 Found BrewPi v0.4.4 build 0.4.4-0-g6d17ff1, running on a Particle Photon with a V2 shield on port /dev/ttyACM0
Unhandled exception in thread started by >
File "/home/brewpi/TiltHydrometer.py", line 361, in scan
blescan.hci_enable_le_scan(sock)
File "/home/brewpi/blescan.py", line 79, in hci_enable_le_scan
hci_toggle_le_scan(sock, 0x01)
File "/home/brewpi/blescan.py", line 103, in hci_toggle_le_scan
bluez.hci_send_cmd(sock, OGF_LE_CTL, OCF_LE_SET_SCAN_ENABLE, cmd_pkt)
_bluetooth.error: (1, 'Operation not permitted')
May 06 2017 16:57:21 Notification: Restarted logging for beer 'test%20TILT'.
May 06 2017 16:57:36 Notification: Beer temperature set to 20.0 degrees in web interface
Hi @kead,
This sounds like a bluetooth permissions problem. Can you try running again the setcap command, then restart the script:
sudo setcap cap_net_raw+eip $(eval readlink -f `which python`)
Nothing⌠i have try but same problems.
In web interface i donât have the line of Tilt.
http://i.imgur.com/u94v6dy.png
Just trying to set this thing up from scratch. Fresh install of BrewPi up and running, and added the files from https://github.com/sibowler/brewpi-brewometer according to the instructions.
TiltHydrometerTest.py finds my Tilt (Blue)
I have tried to run the fixPermissions.sh scriptm but no changes made.
Started a new brew sorted the graphs - awesome work!!
The error messages are still in the log though, anything I should pay attention to?
Strange problemsâŚ
I installed the backup on dropbox. In the backup I can see the Tilt report! Nothing in local display bwp (as previous photo).
Another problem but related to Tilt: it is put into the water but the density grows now after hour (see this picture). Is it broken?
Did you install the tilt integration part-way through a brew? If I remember correctly, the data wonât show on the BrewPi interface until you start a new brew.
I reboot the system, start a new brew, refresh page, change browser⌠the situation is the same
This indicates that the modified web files/scripts havenât been installed correctly. If you can see the graph in the dropbox version, then the data is being logged (this is good).
Can you double check that all the files in the brewpi-web/ folder have been copied over the original files in /var/www (sometimes Brewpi is installed in /var/www/html - so double check there arenât two copies of the files).
Resolved! the correct folder is /var/www/html
Thank you!
OKâŚMy first attempt at this was a bust. At least the BrewPi is still functioning.
First question:
I assume I need to copy all of the sbowlers github files onto my RPi in the exact directory structure as indicated?
brewpi-script
brewpi-web
tiltHydrometer-test
âŚand then run the Setup and Testing instructions/commands?
Hey, I just got my Tilt/Brewometer and Iâm trying to get it working with my Pi/Arduino BrewPi (so Legacy branch).
Iâm having the same problem that Richard_Crump did in this post:
Here is a screenshot from my BrewPi:
I am using jlvnycâs fork of the BrewPi/Brewometer mod (since sibowlerâs doesnât work with the legacy branch from what Iâve read)
You can see that it is showing all the possible Tilt colors, even though none of them have data. It is showing the data from my Tilt (Black) on the graph, but not on the sidebar. There is also no SG scale on the right side of the graph. It is also showing the temp from the Tilt in Celsius (thatâs less important though). The data from the Tilt do show up when I use the test script, and are being logged to the csv file. Basically the exact same problem as Richard_Crump in the linked post
I have âreinstalledâ (recopied and overwritten the files) a couple of times, rebooted, restarted the script, refreshed the webpage. I used the fixPermissions.sh script to fix the permissions. I tried Richard_Crumpâs solution; making sure beer_chart.js was copied over (verified by modification time and by reading through the file to make sure it was the correct version), and chowning the www folder to brewpi, but neither of them seemed to help
Does anyone know what to try next?
Just set up everything! Thanks to all for the documentation and work done. I got some issues but could solve them easily!!
Great!!!
Cheers,
Marc
Maybe try Ctrl+F5 in your browser to force a reload of the files?
It doesnât seem like all the files have been refreshed⌠If you go in your webbrowser to http://<brewpi address>/js/beer-chart.js does it show the modified version?
I donât know about Ctrl-F5, but I cleared browser cache and temporary files,and it started working. Unfortunately it still shows the Tilt temp in Celsius, but it I donât plan on using it.
