You should connect:
12V + --> pump --> DC SSR positve terminal DC SSR negative terminal --> GND
The pump is driven with PWM, so it is normal that it turns on and off. I run mine with a 10 minute period and it only has to turn on for a few seconds every ten minutes.
Working good now, it also helps to monitor the glycol cycling.
So I used the pigtails I linked to above, and then I used some wire nuts and made the connections between the two SSRs. It all worked out very well once programmed and wired correctly.
It was nice to be able to use the old FTSs power supply, and then I used the cooling only FTSs power supply to power the brewpi. Nice that I didn’t have to by anything but those pigtails to recycle some old parts.
I’m using wifi on both the pi and brewpi, and that has been performing great as well.
Slight issue occurred, I was ramping up and the heater will heat, but the SSR light basically just flashes every 2 seconds or so. As such, it’ll be in heating mode for 24+ hours. Any advice?
I have it wired the same as the pump which works normally.
I increased the heater Kp by 1 and I notice it’s now running for longer periods of time. That helps to understand. And by the way I had it programmed, it was working exactly as it should.
Thanks for your patience, I can handle the coding fine, but the Kp, Td, Ti, etc are over my head.
@boasist, I have the parts list and can see what has been explained/discussed in this thread, but do you have any photos of how this is connected and working together? I’m a much more visual person and maybe some pictures will help me connect all of the dots here. Thanks.
My question is kind or related to this post. I am trying to build a fermentation system to managed each fermenter (4 in total) individually. I just bought the Brewpi Spark v3 so I want to know if this is possible:
The idea is to design the following set up:
A glycol tank in a hacked freezer with a pump recirculating through a pipe going pretty much in circles
From that pipe, I want to put 4 solenoid valves to go to each of the jacketed fermenters (4 in total)
Can the Brewpi manage each solenoid valve and each temperature so the valves open and close automatically in order to get the objective temperature in each fermenter?
That way, I can manage each fermenter tank individually and I can do Primary, Secondary, Diacetyl rest, lagering, etc within each of my beers.
Not possible at this time. I am not sure where that comes in at in the timeline but this a future feature to be able to have multiple fermentations on a single BrewPi.
Does anyone have recommendations for using a ftss on a brewpi V1?
I’ve managed to incorporate the fittings into the brewpi housing, so I can just use a single power supply. And heating and cooling are working, but I don’t seem to have as many options for Kp Td etc.
Heating seems ok, but I’m getting a bit more overshoot with the cooling than I would like. I’ve been putting the ‘fridge’ temp probe under the neoprene jacket and have set Kp = 0, Ki =0 kd =0
Is there any way to limit the amount of time the cooling can be on. If I could set it to 20 second bursts I think it would solve my issue
The minimum cooling time is your problem. Glycol is so powerful that it will cool way to quickly. You will have to recompile the firmware with reduced minimum time.
The algorithm on the spark will handle this a lot better because it is PWM based.
Hey Jkeske, I’m looking to control my FTSS heating pad with my brewpi setup. I’ve just acquired the FTSS heating pad, but need to figure out the power requirements. Is the heating pad running off of 12v dc like the pump?
