After updating the script to the lastest version, my brewpi spark keeps rebooting when conntected to the Raspberry.
Before the reboot, the Spark core LED starts flashing red. This only happens with the lastest script version.
I already reflashed the spark with:
python flashDfu.py
This is the stderr output:
Dec 25 2015 20:59:04 Opening serial port
Dec 25 2015 20:59:04 Notification: Script started for beer 'My First BrewPi Run'
Dec 25 2015 20:59:14 Checking software version on controller...
Dec 25 2015 20:59:14 Found BrewPi v0.4.1 build 0.4.1-0-g69ee566,
running on a Particle Core with a V2 shield on port /dev/ttyACM0
Dec 25 2015 20:59:16 Serial Error: Write timeout)
Dec 25 2015 20:59:33 Serial Error: [Errno 5] Input/output error)
Dec 25 2015 20:59:33 Lost serial connection. Error: [Errno 2] No such file or directory: '/dev/ttyACM0')
Terminating due to fatal serial error
sudo python flashDfu.py
Using dfu-util binary at downloads/dfu-util
Detecting DFU devices
Found 1 devices: ['1d50:607f']
Device identified as Spark Core
Latest stable version on GitHub: 0.4.1
downloading https://github.com/BrewPi/firmware/releases/download/0.4.1/brewpi-0.4.1-core.bin
Firmware downloaded to /home/brewpi/brewpi_spark/utils/downloads/0.4.1/brewpi-0.4.1-core.bin
Now writing BrewPi firmware /home/brewpi/brewpi_spark/utils/downloads/0.4.1/brewpi-0.4.1-core.bin
dfu-util 0.7
Filter on vendor = 0x1d50 product = 0x607f
Opening DFU capable USB device... ID 1d50:607f
Found DFU: [1d50:607f] devnum=0, cfg=1, intf=0, alt=0, name="@Internal Flash /0x08000000/20*001Ka,108*001Kg"
Claiming USB DFU Interface...
Determining device status: state = dfuERROR, status = 10
dfuERROR, clearing status
dfuIDLE, continuing
Device returned transfer size 1024
No valid DFU suffix signature
Downloading to address = 0x08005000, size = 109956
File downloaded successfully
Transitioning to dfuMANIFEST state
Programming done
Now resetting EEPROM to defaults
Opening serial port
Dec 26 2015 10:09:03 Opening serial port
Success! Found BrewPi v0.4.1 build 0.4.1-0-g69ee566, running on a Particle Core with a V2 shield on port /dev/ttyACM0
INFO MESSAGE 15: EEPROM initialized
The LED blinks in red short flashes then 8 times in long red flashes, again in red short flashes then 8 times in long red flashes and reboots.
I have been able to reproduce this and I am going to look into it.
It seems to happen when json is generated of all control objects, which puts a lot of objects on the heap. I have been testing mainly on the photon, so this went unnoticed.
You can revert back to 0.2.11 with:
sudo python flashDfu.py --tag=0.2.11
Another temporary fix is to never trigger that command and comment out:
Found a fix. The core was running out of heap memory when creating the JSON output for the control algorithm tab.
In the last update of the script, this was requested at startup instead of only when clicking the refresh button. That is why the core did not crash before when starting the script.
In the update, the JSON output is sent to serial directly, instead of being buffered in a string. This requires less memory and does not crash.
Released a fix in version 0.4.2.
Now I can go back to celebrating Christmas in peace again
Thanks for reporting the bug.
