I would like to turn a second fridge into a meat curing chamber with a OneWire expansion board. The setup needs to be slightly different as temperature and humidity are important. Is it possible to use and monitor a hygrometer to measure humidity as well as control a humidifier?
First, thank you both for the quick answers! @ClaytonRoss, thanks so much for the information and yes, this will be for charcuterie!
@Elco will the device in the link below work without an extra microcontroller? I would like to keep this as simple as possible, if possible. Any feedback you might have would be fantastic.
Hello, I was wondering if you could integrate the moisture sensor in the Brewpi with the Spark control? I want to use the fridge as a maturing room for cheese. Which sensor did you use and what did you adjust in the controller?
