BrewPi Spark update and software developement
I’ll double check that the labels are correct. The address is sent with the packages digitally, so I think it will be processed correctly.
The extension field is necessary for house numbers like 1A.
I don’t see it asking for a house name, it is called house number here:
Mine said housemumber too and also showed below the street name. I was hoping the post office had the smarts to look one line lower, but a label correction would be great. One less reason for them to go postal. :smile:
Ren
Thats my concern the USPS is real persnickety if things are to their liking/standards. See page 5.
Yep, that USPS doc clearly outlines house number before street name with both on same line or delivery could get screwed up. Good call adding the reference uk_brewer and thanks for verifying the labels Elco!
Elco,
Was this an issue with the older store? I just want to make sure because I am still waiting on the Board that ordered a few weeks ago. The one issue is, I didn’t get the tracked postal. So I have no Idea is there are any issue.
All US address go through the Dymo Label address fixer and get an extended postal code and barcode. I’ll send you a photo of your package.
My point was there is no option to enter just a house name (if you do not have a number) typically most sites I use ask for house name/number unless using postcode lookup. You are then free to type ‘92’ or ‘The Cool House’ or ‘Party Flat 2A’ for example!
Minor point but I would hate for precious units to get lost in transit. Especially internationally!!
Dean.
Would the BrewPi Spark work on something like the Grainfather ?? It’s a 1V unit with a simple temp controller like the STC-1000.
I don’t know but it’s be cool if you tried it.
Well i’m picking a grainfather up next week so will be able to have a good look at it. I’ve seen a guy on aussiehomebrewer.com has hooked up an Ardbir controller to his and it worked pretty well.
