Last night I updated my brewpi software using the updater.py as part of that I flashed it with the latest firmware.
My spark seems non-functional after the flash. I have put the spark in DFU mode and run flashDfu.py. This seems to run successfully until the end where it cannot get a version numbrer.
Any tips or pointers on how to fix this?
sudo python /home/brewpi/utils/flashDfu.py
Using dfu-util binary at /home/brewpi/utils/downloads/dfu-util
WARNING: It is not possible to update the bootloader with DFU. If the new release requires an updated bootloader, the photon will automatically download it from the Particle cloud.
This does require a WiFi connection on the Photon.
If the photon does not have WiFi credentials, it will start in listening mode (blinking blue).
Please use the Particle phone app to set up WiFi. Your photon will hang in safe mode until the bootloader is updated from the cloud.
If the photon has invalid WiFi credentials, it will hang blinking green. Hold the setup button for 5 seconds to trigger listening mode.
Detecting DFU devices
Found 1 devices: ['2b04:d006']
Latest stable version on GitHub for photon: 0.5.5
downloading https://github.com/BrewPi/firmware/releases/download/0.5.5/brewpi-photon-0.5.5.bin
Firmware downloaded to /home/brewpi/utils/downloads/0.5.5/brewpi-photon-0.5.5.bin
Updated system firmware for the photon found in release 0.5.5
downloading https://github.com/BrewPi/firmware/releases/download/0.5.5/system-part1-0.8.0-rc.3-photon.bin
downloading https://github.com/BrewPi/firmware/releases/download/0.5.5/system-part2-0.8.0-rc.3-photon.bin
/home/brewpi/utils/downloads/0.5.5/system-part1-0.8.0-rc.3-photon.bin and
/home/brewpi/utils/downloads/0.5.5/system-part2-0.8.0-rc.3-photon.bin
Updating system firmware for the photon, part 1: /home/brewpi/utils/downloads/0.5.5/system-part1-0.8.0-rc.3-photon.bin
dfu-util 0.7
Opening DFU capable USB device... ID 2b04:d006
Found DFU: [2b04:d006] devnum=0, cfg=1, intf=0, alt=0, name="@Internal Flash /0x08000000/03*016Ka,01*016Kg,01*064Kg,07*128Kg"
Claiming USB DFU Interface...
dfuIDLE, continuing
No valid DFU suffix signature
Downloading to address = 0x08020000, size = 239300
File downloaded successfully
Updating system firmware for the photon, part 2: /home/brewpi/utils/downloads/0.5.5/system-part2-0.8.0-rc.3-photon.bin
dfu-util 0.7
dfuIDLE, continuing
Downloading to address = 0x08060000, size = 251580
Now writing BrewPi firmware /home/brewpi/utils/downloads/0.5.5/brewpi-photon-0.5.5.bin to photon
dfu-util 0.7
dfuIDLE, continuing
Downloading to address = 0x080a0000, size = 93860
Programming done
Now resetting EEPROM to defaults
Press Enter to continue...
Opening serial port to reset factory defaults
Jun 18 2018 23:00:21 Opening serial port
Jun 18 2018 23:00:21 Background thread for serial started
Jun 18 2018 23:00:21 Serial (re)connected for Photon [210043000847343337373738] at port: ttyACM0
Warning: Cannot receive version number from controller. It will be reset to defaults.
Exception in thread Thread-1 (most likely raised during interpreter shutdown):
File "/usr/lib/python2.7/threading.py", line 810, in __bootstrap_inner
File "/usr/lib/python2.7/threading.py", line 763, in run
File "/home/brewpi/utils/../backgroundserial.py", line 118, in __listen_thread
File "/usr/local/lib/python2.7/dist-packages/serial/serialposix.py", line 467, in in_waiting
<type 'exceptions.AttributeError'>: 'NoneType' object has no attribute 'ioctl'
