HI
The UI says setting Ti to zero will disable it but it doesn’t. It works with Td.
Cheers
Elco
#2
Thanks for reporting.
Looks like setting Ti to zero prevents the integral from accumulating, but did not reset it.
Already pushed a bug fix, will include it in the next release.
You can manually reset the integral or set it to any desired value by clicking ‘I’.
Edit: tried it. Actually you can only do that when Ti is not zero, to prevent divide by zero here:
Awesome thanks for the quick response.
