Cannot read LCD text from python script / script not running
I have been through the forum posts and the old forum, none of the apparently similar problem solutions have worked.
I decided to update the software on my RPi B and BrewPi Arduino (Uno Rev C?).
All goes smoothly until when the web GUI is running I get the message “Cannot read LCD text from python script” and nothing I have tried will restart the script.
Among previous solutions I have tried:
python /home/brewpi/brewpi.py --kill
“Errors while opening serial port: could not find compatible serial devices”
python /home/brewpi/brewpi.py --status
“No BrewPi scripts running”
The BrewPi physical LCD display indicates the last script it had when connected to the fridge. I have also played around with the cable linking BrewPi & RPi and that does not appear to be a problem.
Anyone encountered and solved a similar problem?
Thanks in advance
David
Please post the output of:
python /home/brewpi/autoserial.py
If your Arduino is listed, but not in compatible ports, that might be a bug.
Add
port = /dev/ttyACM0
To config.cfg to disable automatic detection.
Elco
Python cannot open file ‘/home/brewp/autoserial.py’ [Errno2] No such file or directory
Add
port = /dev/ttyACM0
Where will i find this file?. The only directory is brewpi-tools, with
install.sh
updater.py
update-tools-repo.sh
David
You made a typo.
Navigate to /home/brewpi
Config.cfg should be placed in the settings dir
Hi, sorry to chime in here but i am having a similar issue.
After running “autoSerial.py” i get the following:
pi@raspberrypi ~ $ python /home/brewpi/autoSerial.py
All ports:  ()
Compatible ports:  ()
Selected port:  (None, None)
Any idea? I did fry an arduino in a previous setup when i got some longer sensors (wired one up incorrectly) and i have since replaced the arduino/sensors.
Can you try again with sudo? Do you see any devices with:
ls /dev/ttyACM* or ls /dev/ttyUSB* ?
There was no devices reading so I ended up replacing the Arduino & Pi and it looks like the Arduino board was stuffed so i’ll just use my other Pi for another little project i have in mind.
I just had a whole pile of problems with setting up the wifi after formatting my SD card and reinstalling everything. I finally got it sorted today, and just managed to get BrewPi installed super simply. Thanks a bunch. Lets hope my relays work now, otherwise i’ll be waiting a couple of days while new ones turn up haha
All good, i need to make a starter for the next beer anyway!
Thanks Elco & all above for the posts. Its helped me understand a lot more about the way to work in Terminal/SSH
Just to give an update, uninstalling the heating and cooling devices cleared the device itself and when i reapplied the changes it all clicked on like it should. So pumped to have it back up and running, i also have enough spares to build a second one. Might be able to control my serving fridge a little better and hook up a tower cooling system or something.
thanks again!
