I have tried to figure out why setpoint is at 18 when according to profile it should be 17 degrees. Then i realized there is a difference between the date in the chart and in the profile which maybe has something to do with this. I am however a bit confused as to why the date in the chart is what would be used as setpoint. I would have imagined it was the setpoint in the profile (the redline that follows the date).
Well anyway, does any one have a suggestions to how i can change the date in the chart if that is the problem or a suggestion to what else i could do to make the profile work thanks
I’ve been battling a similar issue to this and it’s possibly since changing houses or modems (not sure).
The beer profile date and time is correct because when I click “insert now”, the correct date and time is entered. Up in the graph though the date is out by about 5 days and I have absolutely no idea why.
I’ve gone into the interfaces file like the suggestion above, however my interfaces file has different lines in it. I reentered the wifi username and password and that hasn’t fixed the problem. I’ve also checked the internationalisation options. I’ve had this brewpi running for about 7 years and the issue appears to have only just started. It’s a real pain as the beer profile option is not able to be used because of the date difference.
In the image, the beer profile day 0 is now, yet the graph shows the 6th Sept (not 11th)
