Doesn’t show up after switching back to Brewblox.
There’s a “path” field in there. It may be using MQTT over websockets.
Try:
path = eventbus (or /eventbus)
port = 80
tried with both eventbus and /eventbus . Didn’t show up
You could also try port 443, in case it uses HTTPS by default, but other than that I’m not sure what the problem is.
Could you please run brewblox-ctl log? Either the gateway or the eventbus service may have logged connection errors.
What are the available settings for the MQTT service type? If it allows for formatting, you can describe the message there.
