And I understand the wiring, but not sure about the layout on the brewpi photon. As I understand, there are 4 Digital Outputs you can hook up to with the green plugs. Each supports a 5v, 20mA +/- wire. Live wire to the +, grnd to the -.
But for the PWM fan, I also need the VIN. I’ll be using external 12V power so the VIN should have sufficient supply.
I have a 12V DC fan with 2 wires that I would like to use as a chamber fan.
When my Brewpi was in Test mode, i connected the two wires to the + & - pins on one of the the digital outputs (in the green block) when i switched that output on with the touch screen the fan worked fine.
Now I have the Fridge and brewpi connected and ready to go ,everything is working fine but the fan does not seem to work.
Is it possible to have the fan run constantly off one of the 4 digital outputs?
But I would just let the fan run continuously on low speed instead of switching it. Find a power supply that gives you the right speed and just connect it without the BrewPi.
