I bought a few onewire temperature sensors to upgrade my HERMS system. A couple of the cables are to short to nicely install them. I’d like to replace the cable that came with the sensor with my own. What type of connectors are you using on your one-wire cables that plug into the sensor? I do have RJ12 connectors to put on once side, I’d need the other one.
I suppose you are talking about the threaded or wall mounted sensors.
The connector on one side is RJ11 (same form factor as RJ12, but with only the middle 4 pins) and the other side is M16.
Hi guys! I am getting started with pi and am excited to find your temp sensor. I don’t think I am ready to invest in a spark yet and just want to use the threaded temp sensor in a thermowell. How can I connect it to my raspberry pi or breadboard? Sorry if this is a easy question, Im just getting started. Wanted to make sure it will work before I ship it across the pond.
We don’t hook it up to the pi, because the BrewPi Spark interfaces with the sensors, not the pi. If you want to connect it to a pi directly, google for DS18B20.
