Im looking into controlling a 230v magnetic valve using BrewPi.
The setup is needed in an alcohol still and the valve should be controlled automatically on/off from a from a sensor value.
The valve should be turned off and on when the temperature goes below a set value or over a set value.
For example off at 23.0 C and below, and open over and untill 23.2c after it closes.
The valve is controlled via SSR.
Is there a ready plugin in the addon reposityory for something like this or do you know if anyone has made a plugin with a command like this?
